Spoiler grille replacement question (pics)
Seared
I removed my stock spoiler today in order to replace the black plastic grille insert. I understand that the grille is held in the painted plastic frame with adhesive. Has anyone removed this before, and if so, what is the best method to separate the two pieces?
Rather than purchasing the 75-part Porsche adhesive, is there an acceptable black urethane that would work just as well?
The car looks interesting without the spoiler in place
Andreas
Andreas
Seared
Originally Posted by psychoideas
Any black urethane that is used to bond windscreens in will do.
I presume a black urethane would be the ticket, as the spoiler frame appears quite flimsy by itself. The adhesive is probably meant to act structural.
Andreas
Seared
Progress. I was able to separate the old black grille insert from the painted spoiler frame. It took a deft hand wielding a razor knife, various screwdrivers, and a generous helping of foul language. The grille is affixed to the frame using a very tenacious adhesive. This adhesive would work fine should one wish to reassemble the Titanic some day.
A local auto parts store had the correct 3M urethane adhesive in stock, so I should be able to reassemble tomorrow:
Andreas
Andreas
Seared
All done. The new grille looks great. The 3M urethane was the ticket - it flowed nice and the bead kept its shape so that both surafces could bond well. I let the adhesive cure for a few hours before bolting it back together and taking it for a whirl. It feels like I gained 15 HP.
Here is the old grille:
And here is the new one:
Andreas
Andreas
