What does a "Top End Rebuild" really mean?
Rennlist Lifetime Member
Originally Posted by Geoffrey
"Huh? That is a misinformed statement as is the recommendation to re-ring the engine simply because you are in there. You should never install new rings in a cylinder without preparing the cylinder for the new rings. You need special honing tools to hone a Nikasal cylinder to get the specified RA value which is require to properly wear in the new rings.
On my recent rebuild the cylinders showed the original factory hone as subtle cross hatching with only a visual indication of the top and bottom edges of the piston travel area; nothing could be felt by touch. I would guess honing the Nikasil is not easy as it's very very hard.
Originally Posted by phelix
What's RA?
1 Post
is top end rebuild a one-time thing or is it a major service that will be required every XX,XXX miles on all 993 Porsches?
If re-rebuild is needed every so XX,XXX miles, what is generally the figure for the "XX,XXX" miles?
And how would one know from daily driving when a top end rebuild or a re-rebuild is needed?
So many questions. I know....Searched for it and saw no info on the re-rebuilding issue.
On the 993, top-ends generally get done earlier because the original factory valve guides are quite soft and wear prematurely, also contributing to the clogged SAI passages that can result in a top-end to pass emissions, even when oil consumption is tolerable.
The consensus seems to be to use a harder valve guide material when doing the top end and the motor will last a long, long time barring any other problems.
Aside from a check engine light due to the SAI passages, the usual rule of thumb is to go by oil consumption and/or leakdown and compression. The oil consumption can vary wildly from car to car, but if you're using more than a quart every 1000 miles, you've got a problem. (Factory, I believe, says 700 miles per quart is okay). Most folks get well more than 1000 per quart, although I had a 95 C4 that used a quart every 1000 miles but had perfect leakdown and ran beautifully.
BTW, I started this string. As you can see in my avatar, I bought the car. It has 84k miles with a fresh top end rebuild with the stronger valves. Compression and leakdown numbers were very strong. I love it, thanks for your your help!
To put it simply, there is no mileage that you can say you'll need a rebuild. There are too many variables.
