Removing Windshield - Quarters - Rear Glass
I did a search and couldnt really find what I was looking for. Anyone have any instructions/pics on removing the glass in our cars? Lexan is going in via a flush mount frame, but I want to be certain I know what I am doing before I attempt to remove the windsheild, rear quarters and rear glass. thanks in advance.
you will hate front lexan glass ! we replace the front glass in paul newmans race cars all the time becouse it gets scratched very ez and all the time . but if you must then what i just used on dannys 993 was a pneumatic windshield tool from the inside of the car place it against the glass push in to the urethane sealant and cut . the QTR glass and rear glass is just a rubber gasket and are very ez to remove . just start in the center of the longest straight edge on the glass . tuck the gaskets in side rubber lip between the glass and the pinch weld were the gasket seats to the body . do this slow and ez around the hole gasket and the glass comes right out . it would be better if i could explain in person you may call me at 203 407 1708 shop phone david
Technical Guru
