Great deal on HIDs!!
I found a great deal on HID's that come with a lifetime warranty for $325 shipped plus 10% off for new customers, so I ended up paying $293 out the door!!!! I put these on my girlfriends A4 and I'm thinking about putting a set on my 993 as well. Anyone up for a group buy? If enough people are interested, I'll see if I can contact the company and set something up.
http://www.khoalty.com/bmw_e46_lights.html
As usual, no affiliation, just sharing a good deal.
UPDATE: I'm going to start a list of potential buyers below. Also, does anyone know the proper procedures to setup a group buy on rennlist?
1. KraZy007
2. 95FL993CAB
3. Land Jet
1. KraZy007
2. 95FL993CAB
3. Land Jet
These look just like the set that I bought off of an eBay seller (yes, in China). They were $155 shipped. I had some trouble with defective ballasts but ended up getting it resolved. It took way too long and much negotiation. I would not buy from the same seller again but these kits are likely coming out of the same factory. There are numerous Chinese sellers selling this on eBay.
If I were to do it again I would buy from a supplier in the US to make dealing with problems easier. Shipping was the main point of contention and sending things back to China in this case was very cost prohibitive. We ended up working it out but it took over a month.
They appear to be the Phillips-style ballasts and I would not be too surprised in Phillips sources them from the same place. Based on my experience I am sure quality control is better via Phillips.
All of that said, I am very happy with the results. These light are awesome. I wnet with the 4300K bulbs and they are bright!
Just thought I'd toss this out there in case anyone was thinking of buying from Chinese sellers.
Originally Posted by Land Jet
I have heard that the wrong after market HID's can melt 993 headlight lenses. Anyone know anything about this?
I would be interested if it's compatible.
The housing and other parts are plastic... but no melting.
Actually, if you search this forum, a really smart guy here (I found out too late!) mounted the ballast INSIDE the lens assembly. Very cool.
We did some testing and determined that the ballasts themselves do not put off too much heat to do this. The style of ballast is like the one above, "Phillips-style".
If I were to do it again this is the route I would go.
I see two sets on the site. What is the difference? Does anyone know?
Hope to have found a set for $200 or a little under but if that falls through this may be the way to go.
It looks like the less costly set has a 2 year warranty whereas the pricer set has a lifetime warranty, but other than that, i'm not sure. I'll try to get an answer on that and update the thread.
Here's the thread with the pictures...
https://rennlist.com/forums/993-forum/336973-aftermarket-hids.html
$300 does seem a little pricy to me though..
I thought the ones from Vertex where much cheaper than that....I can't remember what I paid but it was just over $200 I think...they seem to work fine.
Cheers,
Mike
Cheers,
Mike
I would stick with Vertex if you are in the US. Their customer service is great if you have issues. DO a search & you will find a lot of us have installed the HID kit from Vertex.
I bought the same HIDs recommended by Caveman. Mine were $155.00 delivered. The install took about 2 hours (see pic: ballast trunk install using ballast brackets provided with kit). Mine have worked great for the month that I have used them.
I bought a HID kit for my corvette that I never installed. I wonder if there is any chance at all it would work in the 993. I will have to look into it. It would save me some $$$.
If it does not, I would be interested in a group buy for a proven HID kit.
Some lotus owners use this kit, which is pricey but has a tiny ballast that would definitely fit in the lense:
Lotus HID kit
