So how hard is it to do a suspension swap...
I'm just about to pull the trigger on doing a the suspension upgrade to Bilstein HDs and MO33 springs on my 98 Targa. My understanding is an install will run around $1200. I'm thinking for that kind of money, if I can get it done over a weekend or two I'd rather take it on myself. I know I'll still have to get an alignment and corner balance, but that should run around $300 or so right?
I'm pretty good with a wrench and have a good set of tools, jacks etc. So how hard is it to do the suspension swap and how long will it take? Any tips, tricks, or thoughts? I remember a link around to a doc that outlines the job. Where was it again?
Thanks,
Thanks,
Thanks,
Thanks,
With Jeff's directions...
not bad..did it myself...piece of cake..did have to read up on jacking up car though..
Use Jeff's excellent write-up. I'm really slow and it took me maybe 15 hours including
jacking the car, measuring current settings, a couple fights with bolts, getting the garage ready,
and a trip to Sears for a tool. If you're handy with tools its doable.
The water's fine, jump in.
Honestly, I was in the same boat as you are. Although you say you are pretty handy with the tools, you don't need to be. Doing a suspension swap is more intimidating than it is hard. Just take you time and....have fun!
<thanks for the nice words above>
Originally Posted by Father of 3
Call Darin at Westend in Torrance, California. All in cost is less than $600, I believe?
Originally Posted by InTheAir
But, that is without internet forum braggin' rights.
If you buy from ViperBob, he will most likely lend you the "tricky" tools, such as the sockets with open sides.
But, in all honesty, if I could get the suspension installed and get a corner balance/alignment for $600, I would have had it done. (gulp) However, in my case, my quotes were for $1200....for the install ONLY.
That being said, I KNOW I took greater care in the install than a tech would.
PS Armorer
I was also in your situation a while back. With basic mechanical ability and decent tools (don't forget the Hazet socket) it should be no problem. I did it over a weekend, completely by myself, using instructions from Robin's site (this was back in 2002). Besides the extra $6-1200 in your pocket, you get 1) the aforementioned internet bragging rights , 2) the knowledge of what's what in your suspension, and 3) the satisfaction and piece of mind that the job was done with care (sway bar bushings lubricated, bolts tightened and torqued properly, etc).
Good luck,
Jason
Good luck,
Jason
I actually have Bob’s tools right now. I just finished up my install. It truly was a lot of fun and very rewarding. I ran into a few SNAFUs, but Bob was with me every step of the way. I had my rear shocks in and out a few times (Shock problems replaced under warranty) and I got to where I could get them out or in in less that 10 minutes! I didn't know whether to or !
And if you know his shop, you know he's putting your car together with close to the same care and attention you would yourself.
I was actually kind of looking forward to doing the job myself!
Thanks,
Thanks,
