Deck Lid Badge Delete...
Some A-Hole attempted to "delete" the Targa badge on my rear deck lid. They only managed to get the T off snapping the badge in process, so now I'm driving an "arga". It left a bunch of the dried out black backing adhesive where the letter was. So I have a couple of questions:
1. Where can I buy the badge from.
2. How do I best remove the original badge and get any adhesive residue off. Its very dried out. I'm thinking "Goo Gone". I've used Brake Cleaner to remove adhesive before, but I don't think I want to apply it to the paint on my rear deck.
3. How do I make sure I get the badge back on in exactly the right place.
Thanks for your help.
1. Sunset Porsche or other dealer for badge. There are others that sell these but Sunset is likely the best $$
2. I have used "Goof Off" without damaging paint but not on my pcars... I'd test it in an inconspicous spot first. I think it will be OK but ya never know. I'm a little more "careful" with cars I care about.
Anyhow, Goof Off works great on sticker goo.
3. I'd just measure where it is now, top to bottom and right to left. You could probably make a template of some sort to make it easier to position the new one. I would guess you will still see an outline even after you clean the goo off.
Good luck!
Good luck!
Bummer. I hate to see things like that happen.
Parts at dealers cost (+10%) www.sunsetporsche.com
Try the dental floss method to remove the remains of the emblem.
Go easy with the solvent for glue removal.
The Targa emblem probably left a "shadow" that you can use to line the new one up to.
Best of luck.
Best of luck.
To remove the old stuff, I sprayed alcohol diluted with water (50-50) in direct sunlight, and rubbed with finger, not nail...
don't think i'd use the brake cleaner or any solvent except like the above poster said.
I'm paranoid about someone taking mine off like you had happen.
on a side note where do you get the '911' or '993' badge that I've seen floating around. would like to replace my current one
As for the arga removal; use a blow dryer (or heat gun if you have one) to heat the emblem and dental floss to pry it off. Goo gone will remove the left over adhesive.
Cheers,
Stan
Cheers,
Stan
Thanks for the advice. Dental floss method sounds like the way to go. Yes I expect there to be some paint change where the original logo was.
Joe--agreed on the KTMs--have a 05 525 MXC and 05 950 Adventure.
Seared
Steve,
I recently replaced my black 'Carrera' emblem with an identical one from Sunset. The original had lost its ties to the adhesive in some places and was ready to crack the next time I washed the car.
I used a heat gun to soften the old adhesive, then gently sawed through the black stuff with a length of fishing line. After removing the emblem, I used bug & tar remover to soften the adhesive and my fingernails to gently remove the stuff. After it was all gone, I cleaned the decklid and then polished it as I would the rest of the car.
I tried all sorts of measuring technigues, blue tape lines, you name it. But I was never confident that the new emblem would land where it should. So I took a regular black felt-tip marker and made a black dot in the middle of the "a", "e" and "a". Enough of a shadow remained that I was able to see these letters.
Then I removed the backing and carefully hovered over the three black dots until they all seemed centered with the new emblem letters. Once you touch the decklid, it's all over. The adhesive is there to stay.
Afterwards, I waxed the decklid, being careful not to get anything between the letters.
Andreas
Andreas
Originally Posted by Crimson Nape Racing
I got a "911" badge from Performance Products a couple years ago, but the shadow under the " Carrera" was so bad that it looked terrible. I put the Carrera back on and will put the 911 badge on when either I have enough guts to paint the deck lid or a few hundred bucks that I don't need. I think I'll have the emblem for a while.....
