Engine and Transmissions Differences - 993 to 996 to 997
After some searching and reading, I still havent found a CLEAR and CONCISE summary of the engine and transmission difference from these last three series
I understand the dry sump issue, cable linkage on newer transmission, but I am hoping that some of our more technical types might respond with a summary or recommended reading source on this topic.
thanks!
thanks!
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
If it wasnt for the quality troubles of the water pumper engines, their technology is wonderful!
The watercooled 911 engines are much less modular which, by design, offer less places to leak from but also MUCH less expensive to manufacture. Four valve heads, DOHC with Variocam technology are the highlights of such powerplants.
...ok, let me see if i can prod this along....
- 993 engines and trannies are quite solid, hand-made, dry sump, gt1-derived, etc. HOWEVER, we will all need clutch transplants in the not so distant future at $3k ish, possibilit of top end rebuilds at $10k, etc.
- 996 engines have RMS leak problems, otherwise ok? 996tt bottom end based on 993, so probably much better than the 996 NA? Shifting uses cable linkage, much tighter feel when shifting, but the trannie is "throw away"?
-997 engine --- largely the same as 996, but RMS leakage issue solved?
help.... please... thanks
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Actually, a linkage shifted trans will be more direct than that of a cable shifted type. All manual trans cars will require clutch replacements, which shouldnt differ much in terms of price.
I know someone will correct me if I'm wrong , but my understanding was the 996 Turbo engine actually used the same block as the 993 (dry sump and all), but just had water-cooled *heads*. The non-turbo 996 is a wet sump, completely different block made of the aforementioned beer cans and Subaru tooling.
It's only for this reason that I sometimes think of looking at a 996 Turbo. But I still can't get past the funky headlights and lack of curves. Good thing I still enjoy my Targa!
-Chris
-Chris
-Chris
-Chris
-Chris
-Chris
Lifetime Member
Lifetime Member
Originally Posted by RallyJon
I heard 996 and 997 engines are built by slave labor in Chinese prisons using melted down beer cans with tooling bought used from Subaru's scrapyard.
FYI, the Cayenne "automagic" tranny is from the Toyota Land Cruiser....
Originally Posted by Pete Lech
Well, right part of the world, anyway, for the trannies. The 997 tranny is made by Aisin in Japan, has triple synchros on 1st and 2nd, and doubles on 3rd and 4th. THAT should help the weak synchro problem of the 993s. The short shifter is bitchin'
