993 Forum 1995-1998
Downgrading to 17” wheels
Old 12-20-2006, 03:54 PM
tj90
tj90's Avatar
Do you have a link? The only carrera II wheel I can find is the 17" 10 spoke. Is that the one your referring to?
Old 12-20-2006, 04:30 PM
Thaddeus
Deer Slayer
Thaddeus's Avatar
TJ, your avatar makes me break out in a sweat. A forklift lifting another forklift? Darwin award candidates for sure!
Old 12-20-2006, 06:32 PM
Edward
Addicted Specialist
Edward's Avatar
Originally Posted by 993inNC
I'm not sure I agree (with all due respect). I've been smoked by NA 993's with 17's and can only attribute (having spoken with the driver - also an instructor in my group) that the 17's with a low profile tire allow for a decreased gear ratio which tends to help on tracks where our normal gearing is to tall for one gear and to short for the other. The 17's provide the happy medium and really seem to help launch off the turns....
That's what I meant when I alluded to all else being equal ...differences in rolling diameter will most assuredly affect acceleration. The gist of my post was that a simple difference in 18 vs 17, and say a 35 vs 40 aspect ratio, and a minor diff in wheel weight, in and of themselves will not result in drastic handling diffs on the track, let alone street driving. I'm talking apples to apples, here: same car with a simple wheel swap with identical tires and an aspect ratio to maintain like diameter. Affect ride compliance yes, but lap times?? ...well if you're Shumey or just that darn talented.
Edward
Old 12-20-2006, 07:28 PM
pedsurg
pedsurg's Avatar
Don't forget that 17 inch tires are also cheaper than the 18's. If you're running Hoosiers at the track it can add up quickly.
Jack
Old 12-20-2006, 08:51 PM
tj90
tj90's Avatar
Glad you like it - I was shocked when I saw it. I have another one where a guy is welding a muffler under a small pickup that is propped-up by a 4x4. Insane.
Old 12-20-2006, 09:07 PM
clib
clib's Avatar
Originally Posted by tonytrini
Do you have a pic of your car with the 17s?
TIA
here's a couple of pics - one with the two C2S cars together - primary differnce is the wheel size (and his is that awful color!) with stock 17 in. wheels vs. 18 in. and then one of mine with the 17 in. kinesis
Old 12-20-2006, 09:11 PM
tonytrini
tonytrini's Avatar
Thanks!
The 17's rock..
Old 12-20-2006, 09:20 PM
Thaddeus
Deer Slayer
Thaddeus's Avatar
I LOVE those Targa Wheels. I want some.
Old 12-20-2006, 09:37 PM
Chuck W.
Chuck W.'s Avatar
Not that I ever get tried of showing off the 993....I got the Targe wheels a couple of weeks ago off of the local Craigs List for $500.
Old 12-20-2006, 10:08 PM
Thaddeus
Deer Slayer
Thaddeus's Avatar
You DOG!
Old 12-21-2006, 10:33 AM
pcar964
pcar964's Avatar
Originally Posted by Edward
Honestly, suspension/tire widths/etc. being equal, I doubt there is much real-world difference between 17 and 18. I think perhaps a verrry good/seasoned driver can exploit the latter's advantages in a track setting, but for street use, even aggressive canyon runs, there just isn't enough of a performance delta to spend a thought on. Barring super-heavy crap wheels, shod the ones that you think are the best looking.
Edward
I have to disagree. There is a noticeable difference in grip with the 18" HS compared to 17" cups, all else equal, in my experience. I'm not just talking "it feels stiffer," I'm talking more overall grip. More contact patch, less deflection... 17s have too much sidewall flex unless you're using a tire with stiffer sidewall, i.e. R-compounds.
It's possible on slower tracks that the 17s lighter weight and slightly better acceleration would be faster... but on a track like Sebring with fast corners, the 18s are faster.
Old 12-21-2006, 10:40 AM
RallyJon
Weathergirl
RallyJon's Avatar
Originally Posted by pcar964
I have to disagree. There is a noticeable difference in grip with the 18" HS compared to 17" cups, all else equal, in my experience. 17s have too much sidewall flex unless you're using a tire with stiffer sidewall, i.e. R-compounds.
Ugh. This is the catch-22 I hate. Stiff sidewall = rim protection (mandatory) = great turn-in (good) = heavy (bad) = lousy ride (bad). Soft sidewall is just the opposite. So you can run softer tires in lower sidewalls and get the effect of stiff sidewall taller tires, but you are very susceptible to rim damage from less sidewall height and less resistance to bumps.
Which is why I always end up with the stiffest tires availble with wheels that are somewhat smaller than optimum if handling was the only concern. And I put up with the thumpy ride and effects of too much rotational momentum.
Quick Reply: Downgrading to 17” wheels
