Spoiler Bearing Part Number?
Hey guys, I know I'm resurrecting an old thread but I came across this during a search. My spoiler gearbox isn't too noisy at all right now but I can slightly hear it when I'm at idle during a stop when the spoiler retracts. Thought a bearing replacement would be a good winter project. I noticed that there is one on Ebay, Item # 250190541261
My question is whether part number 625-2Z/+P63 on eBay would work even though the /+P63 is different than the /C3LHT23 shown in the picture above. Any bearing experts on here?
Thanks!
Thanks!
If you can barely hear it now, the bearing may still be good as new. Keep it that way by sealing the cable to the case with a wrap of stretch tape or a wipe of grease.
Awesome, thanks for the info Garth. After further reading last night, and the PITA it sounds like to get the gear case open and then re-sealed I think I'll do just what you said, seal the cable to the case. I have a roll of coax-seal from back in my amateur radio days that I may try.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
An O-ring placed onto the drive cable near the wing motor transmission can prevent water from running down the cable into the bearing. I believe this is what causes the bearings to go bad.
another method: i smeared anhydrous lanolin around the junction after shooting Kroil[ the OIL that Creeps} into the junction when parked on a driveway nose down so gravity helped the Kroil get in. the Lanolin intruded into the junction seems to keep the water out , very sticky stuff lanolin. maybee im deaf but barely hear it 105K miles.
.02, ds
.02, ds
I had the grinding noise for years. Until I squirted anti-corrosion oil onto every moving part a few weeks ago. Voila! It's been silent since. So much so that I've had to raise and lower it manually when the car's parked just to make sure it's still working (that noise was good for something!).
