Newbie Stick Shift Removal /Swap Question
Hi Everyone,
Can someone please let me know how to remove the existing oem stick shift. I purchased a carbon fiber version and would like to replace the old shifter.
Thanks so much
Jordan
Thanks so much
Jordan
Originally Posted by shattergard
Hi Everyone,
Thanks so much
Jordan
Thanks so much
Jordan
I assume you mean the ****/boot - not the shift lever?
If just the ****/boot, you release the left side of the boot by pressing straight down, the right side then pulls out. The **** is just rubber friction - pull up hard.
actually, there is a clip that holds the **** in place. i would pry it back a bit and then lift off the ****. it might also be easier to take off the whole console thing (i did it this past weekend it was pretty easy: just a few screws to take out)
Technical Guru
Originally Posted by JasonAndreas
And when you pull up hard don't lean any part of your body (especially your face) over the ****. ![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
Scott
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
I put a vice grip on the metal shift arm under the boot and below the **** and and used a pry bar between the vice grip and the underside of the ****. Like butta.
