Brake Disk thickness
Can someone please give me the minimum thickness on the Rotors.
The car has 86K on it and best I can tell the rotors have never been replaced. Crossdrilled from and rear with 17's from the factory. I need from and rear minimums.
Tks in advance
Tks in advance
are they standard or big reds?
the min thickness is actually printed on the sides of the hat portion of the rotors (sometimes you can't see it any more)
IIRC min thickness front is 30mm and min thickness rear is 28mm but someone else might want to chime in (and I think that is for big reds)
Originally Posted by Bill Verburg
symetrical machine limits are
front 30.6mm same as for Big Reds
rear is 22.6mm
wear limit is 30.0/22.0mm
rear is 22.6mm
What is Symetrical machine limit?
Standard Brakes not big reds.
So I assume same measurments apply
Passed On
Buy a shop manual, cheapskate. Lots of good info in it like minimum thickness is 30.0 mm front and 22.0 mm rear (standard C2/C2S; I'm not digging for C4S stuff.)
