Why I think removing engine tray is no good....
#62
Final results!
OK - I repeated last nights driving test with the engine tray on. For easy comparison, I relisted the results. Fortunately, ambient conditions are exactly the same as yesterday (thank God I live in San Diego!)
Time / Tray On / Tray Off
00min / 21C / 21C
Start car and idle
12min / 106C / 98C
24min / 140C / 126-156?C
Drive car for 30 minutes, stop, immediately take measurements
54min / 126C / 125C
Stop car and cool down
64min / 117C / 114C
74min / 109C / 106C
After reviewing the results, I wish that I had a better 24min idle temp measurement.
1) It appears that the idle temps were higher (~8C) with the tray installed. Hard to say what is happening at 24min of idle, I think the TC may have been faulty- no tray to keep it positioned on the block and slight movements caused wild temp swings.
2) While driving the car, no difference of temp at the head. Both cases, much cooler than extended idle.
3) Cool down with the tray in place caused head temps to be higher by 3C.
I guess Im eating some crow - removing the tray keep things slightly cooler in idle and cool down.
However, I still have my dignity because the tray does not cause hotter head temps while driving (where I spend 95% of my time). Also, the idle differences measured only differ by a maximum of 8C - about the temp difference between your monitor screen and the room.... It would be hard to convince me that this is responsible for added wear of the valve guides, but maybe Im completely wrong... Leaving the tray on maintains under car aerodynamics and allows airflow around the 993 engine and tranny as Porsche intended by the aforementioned patent cited above.
The take away for me is that there is negligible differences with head temps whether the tray is on or off, but what really generates heat is extended idle. Even without the tray, head temp climb 20-30C higher than if we cruise at 45 mph. This is illustrated by the immediate drop in oil temp just by driving like a grandma after extended idle.
BTW, the 24 min of idle cooresponded to oil needle at ~9pm. I have driven to 9:30 tracking the car and sitting in 405 traffic. I would shut down the motor, or stop it with fan still on, if I got to 10 pm. Keep in mind that you dont hit the red until 11pm. Maybe the motor can get much hotter than we give it credit.
00min / 21C / 21C
Start car and idle
12min / 106C / 98C
54min / 126C / 125C
64min / 117C / 114C
74min / 109C / 106C
#65
Originally Posted by brucec59
Um... do you have it backwards? Your Tray Off temps are higher. Should your columns be
Time / Tray On / Tray Off?
#66
Mines done 155k miles with the tray on without engine being opened. I'm leaving mine on ! Results very interesting. One positive for tray being on must be quicker warm up which can only be good for the engine especially in moderate climates.
#68
Thanks for posting all this, it's very interesting. It actually makes me consider reinstalling my cover for DE events in order to get the underbody protection and aero benefits. I say this because there seems to be negligible difference when driving; the car only runs warmer at idle, which is not much of an issue at DE events. The cool-down curve is a little extended but that's largely irrelevant.
#69
Thanks - Im glad to help. What I find interesting is that the data I collected with and without tray is very consistent with the 964 data collected by Arjans. My understanding is that the 964 engine is different than the 993, yet head temps are very consistent. Arjans conclusion was that heads dont get any hotter with the tray installed.
I also forgot to mention that my original concerns of the heat exchanger outputs right under the engine do not seem to add any more heat to the motor. I measured the output of the exchanger outputs and it was much cooler (70C) than the heads. I am thinking now that the reason porsche vented exchanger outputs to the exterior of the tray was to promote venturi effect that was mentioned above. Maybe they get better flow thru the heater system...
I encourage others to investigate this - the more data the better. It would be great if someone can figure out how to instrument and log data while the car is driving. Maybe some can resurrect old data collected or contact the patent holder Preiss at Porsche AG to comment....
#71
Originally Posted by tj90
... It would be great if someone can figure out how to instrument and log data while the car is driving. ...
EDIT: I think actually we have cylinder head temp sensors...see below.
#72
Originally Posted by TheOtherEric
Actually, it would be pretty easy for those of us who use data loggers. There's already an intake air temp that's easy to tap into and log. Unfortunately, there's no cylinder head temp sensor (AFAIK) so that's the tough one.
I have already been accused of being too **** about this (which I dont refute), so I will let another person on the board continue the experiment.
#73
Ok, actually I think our cars monitor cylinder head temps already, but I'm having a hard time figuring out what Porsche calls it. I think pin 45, labeled "ECTS II" and also referred to as "engine temperature" must be it. If so, it would be easy to log intake air temp and cylinder temp to do this study. Can anyone confirm what "ECTS II" is?
#74
Technical Guru
Originally Posted by Greg Fishman
For the 993? The 996 has a ACO mandated underbody tray, but never seen that on a 993 that ran in IMSA under (supposedly the same rules)
Originally Posted by jnx
That passenger mirror is burning up!
#75
TJ, thanks for the effort, makes me step back and think about this again. Assuming that temp is not as big a difference as once thought, the ability to detect leaks vs losing aerodynamic benefit/purpose of tray according to patent is now bothering me. Probably will go with it again and just watch leaking when doing oil changes, etc.
Also want to commend you on ability to take on topic that I sure was going to end up in a flamewar and actually turned out to be civil and informative - good job all around.
