Brake caliper refinish question:
Small favor; can someone tell me what the size of the lettering is on the calipers?
I don't have my car here and I want to order the stencil to letter once I finish re-painting. There is a choice of sizes hence the question.
TIA
TIA
Lifetime Member
Lifetime Member
Both of the front and rear are 3" in length. If they are using the correct eps file format released by the Porsche maketing department then they would be able to get the ratio correctly when they enlarge it to 3"
Lifetime Member
Lifetime Member
The length of the entire Porsche logo is 3"
Here is a link to download the original Porsche logo file, if you have a program that can open EPS files you should be able to stretch the logo to 3" in length and the height would be porportionally corrected automatically to the 3" length.
http://p-car.com/porschelogo/LOGOBLK.EPS
Lifetime Member
Lifetime Member
FWIW, instead of sticking on the decals, the method I used was to use the sticker as a stencil with the Porsche letters as cut outs. I then sprayed 3 layers of high temperature white paint. After 4-5? years, the white color is still very white and no fade or chips.
![](http://p-car.com/caliper/calipermask.jpg)
Thats why I was thinking of stencils. I'm going to have this car a long while and would like do this once.
Robin- got an after pic?
