Found an easy way to remove the bastard SAI valve
button queen
For next time. http://www.amazon.com/gp/aw/d/B000I1...n-L&ref=plSrch
Also, don't forget anti seize and a washer when reinstalling. It turned out to be the same washer as the engine oil nut washer. I did just a snug past handtight.
https://rennlist.com/forums/993-foru...ve-washer.html
You should be able to just hold it up against the side of a grinding wheel and do it yourself in a couple of minutes for someone not wanting to buy the Pelican one, but there is a chance some crowsfeet start out bulkier overall than others and still may not work. It is tight, and takes some wiggling, even with the Pelican one.
Take the crows foot to a machine shop and have properly Blanchard or surface ground to your desired thickness.
Nice catch. Plus, as much as I love my air chisel, I'd be nervous to use it in that tight spot with all the other lines around. I bought the modified crowfoot from Pelican, works well.
