LSD Group buy??
#32
Technical Guru
Has anyone here ever rebuilt a Porsche LSD? Is it possible to transplant just the 8 discs (4-inner & 4 outer) from the 964 to the 993 LSD? I priced out the replacement costs to rebuild (discs, seals, bolts) my 964 LSD and including the special tools, retail is a little over $400 (unless I forgot something). Retail on the inferior plate package for the 993 is over $600.
#34
#35
Originally Posted by Ron
I thought Paul Guard sells the discs to replace the ones that came in the factory LSD units.
#36
I will contact VB and Steve Weiner for further guidance. Then maybe Gert could get involved.
#37
I was going to install a Guard unit, but after talking to Brian Copans at BMC & G (Ohio, 513-779-3302), who is the factory authorized transmission guy for ALMS Porsches, I decided to follow his recommendation, which is to rebuild the factory LSD using Guard ramps and a Porsche Motorsport clutch pack. (Application: 100% DE car) I bought slightly used Guard ramps (60/40) for $300 and a new PMS clutch pack ($580) from him. If your LSD case is in good shape, it should only be another few hundred bucks to have this stuff installed, since it can be done without engine removal. If you're a racer who does enduros, he advised installing a transmission oil cooler, but for DE or sprint racing, a cooler is not necessary.
I'm picking up my car today, but I'll have to wait until April to give it a try on the track. You can see why in the photo below.
#39
Technical Guru
Originally Posted by Monique
I chatted with Adrian Streather. He thinks the LSD fitted to the 964 (4 clutch plates instead of 2 in 993 LSD) will fit fine in the G50/20 etc gearboxes fitted to the 993's.
#40
Thanks Monique for doing the leg work on this, and Jason for your inputs. I am hoping that the proposed Guard unit has sufficient labor savings included, ie it would have cost me to assemble the separately supplied ramps and clutch packs into my existing OEM LSD.
#41
Hello Jason,
The statement coming from you means most mortals should not try it out.
Apparently, changing the clutch plates is easy. Dixit a reputed Belgian racer I know.
Adrian and Steve W think the 964 LSD is a good fit. Awaiting VB's take... then we see where we want to go... but at equal proce, me thinks I'd go Guard. But then they have to aswer my phone calls or emails.
#43
Are you guys sure that the 964 lsd has 4 plates? I was under the impression that they were all 2 plates from around 1984 , except for the motorsport lsds used in RS and turbos.
#44
Hello Kahuna,
Asked the question from a specialist a few moments ago. Stay posted.
For Jason,
I considered the option of rebuild but abandonned the thought after I was told 8 hours labor plus $700 for the plates. Apparently the snag is setting the torque correctly...
If we can get a drop in unit for equal or less money than parts + labor.. aren't we winners? Asked a specialist for a quote on the Porsche Motorsport unit... problem is that Motorsport are closed till next week.
It ain't over til the fat lady sings!
For Jason,
#45
Technical Guru
