993 Wheel Offset Table
Has anyone seen a 993 wheel offset table on Rennlist? I have been searching but not finding anything. I have a 1995 C4 and am trying to cross reference some wheels.
Thanks for the help, |
Offsets listed here
max ~ good to see ya around. missed ya on the run. ya must be up where it's cold. :cheers:
Thanks for the help, There is the "standard" set of wheels that are pretty much guaranteed to fit - for 993s, 18x10 ET65 and 18x8 ET50 - but once you go beyond 1/2" or so either in width or offset there are no fitment guarantees since clearances on older porsches can vary from car to car, not to mention even side to side on the same car. I believe the most aggressive that is practical for a 993 (ie requires minor fender rolling but no cutting or repainting) is 18x11 ET52-53 and 18x9.5 ET45. There is a thread from a few weeks ago where a Rennlister (Bill?) had posted some sizes and offsets that from his first hand experience would fit. Also if you are willing to get on your back and do some measuring on your car, there is an offset calculator you can use at TireRack.com. Good luck:cheers: |
Ok...how's this for trivia...
'97 C2S 18x9 in front? What offset? Will they clear with no rubbing? 18x11? Anybody have any experience with this width and not rubbing? I guess I can stick with 10" rear widths, but I'm trying to get a little more rubber on the ground. |
Originally Posted by 24FPS
i believe david has 18x11's on his cab. don't you david? rolled fenders & 11's results in a great agressive look (imho). :evilgrin:
I put together some info here, look below the 911 stuff
Thanks for the info Bill.
Thanks for the info guys. Not really looking to roll the fenders, so I'm looking to get as much meat on the rear as possible before making modifications to the body.
Originally Posted by David in LA
I don't have a C2S but the 996 turbo twist are 11" and fit widebody 993s w/o rubbing and no fender rolling needed - there are a lot of 993TTs running around on these...IIRC the offset is still ET45, so this would be a fairly safe setup. For the front, staying with ET50 but going from 8" to 9" should also be OK but a bit of fender rolling may be needed depending how much your car is loweed. BTW you can go 10-20mm wider w/o having to get new wheels.
Yesterday 11:17 AM Since it will be for a track setup, I am assuming that the front width is not as important as the getting more meat on the rear. Afterall, I'm not looking for more push... Thanks again! |
18x9 in front? What offset? Will they clear with no rubbing? Since it will be for a track setup, I am assuming that the front width is not as important as the getting more meat on the rear. Afterall, I'm not looking for more push... Use 8 or 9 & 10 or11 225/40 or 235/40f and 265/35 or 285/30 rear for street because understear there is sort of desireable but for track 8 & 10 225/40 and 265/35(R rubber) will give you a quicker car |
Bill,
Thanks for the advice. Does this change at all for the C2S? |
Does this change at all for the C2S Bigger rear wheels or tires relative to the front means more push, which has to be dialed down via suspension tuning. Again for track(street doesn't really mattermuch) If you go bigger in back try to go bigger in front, but the tire you chose will limit you For MPSCs 235/40 front and 285/ -315/30 rear for a more street oriented tire like the Advan Neova you would be limited to 235/40 and 295/30 by tire offerings I am sure that someone that actually tracks an S(not me) may offer some other relevant insight. |
My experience supports what Bill is saying. If you don't want fender mods, I like 235 front and 285/295 rear.
Thanks for all the help. I am looking to get a set of 17" CCW track wheels from a buddy that has a 1996 C2. He is running 245's on front and 265's on back. My C4 is stock and is running 205's and 255's on 17" wheels. I wanted to make sure they would fit.
I do not want to get into any mods on this car. My 944 is where all the mods are going. However, my wife is as big a fan of DE's as I am. One day it will be the track beast. It is very fun on the track for 17 years old! I was curious if by coincidence the CCW's would fit both cars. I know it is unlikely, but I thought I would ask. Ryan |
