Who has coolest wheels on their 993?
#1503
HI,
I have a 993 Carrera (narrow body) recently bought from a friend as used car which is bone stock. One of my upgrades is to install new BBS LM wheels for the fronts with 8 x 18 and 8 x 11 for the rear? Will this work and will not rub down both fenders in the front and most especially the rear? Or should I just get 8 x 10 for the rear since narrow body. Hoping for your replies with sample pictures of LMs installed on narrow bodies. Thanks much
#1509
Thanks Phil. I just like a wider lip at the rear to show the staggered or broken size effect of the BBS LMs. I do not know with the others if fender rubbing is an issue if I put the 11s or 10s You think they will stick out of the narrow body fenders? Anyone here in the thread with 993 narrow body who used 10 or 11 BBS LMs. Pics please thanks.
#1510
https://rennlist.com/forums/newreply...ply&p=11196902
There is also a new thread on BBS LMs for 993s, if you wanna see pics of various setups. Pretty sure no NB is running 18 x 11 in any of the pics.
https://rennlist.com/forums/showthre...ferrerid=66189
#1511
BBS LM 18 x 11 I believe offset is et 56. That will not fit the rears of your NB, read this thread as reference:
#1512
Hey David! I used your rears for the front and found wider outer hoops for the rear in order to nail the look. Front: 18x8.5" Rear: 18x10".
Just coated the brakes yesterday in order to keep with my Cardinal and Gold theme.
#1513
old turbo with Fikse Profil 13
#1515
May not be the coolest, but probably one of the tightest fits. 3mm either way in the rears & I'm scraping metal..
Kinesis 8.5 / 11 x 18
