993 Rear Spoiler Adjustment
Old 09-05-2005, 02:09 AM
993cab
User
Default 993 Rear Spoiler Adjustment
I was cleaning up the car and I noticed that there are some wear marks where the rear spoiler meets the engine lid. Are there any adjustments because it seemd that it is closing too tightly and thus the wear?
I am curious to see if anyone else has this problem. It is not often that you even notice it because the spoiler is normally on auto mode.
993cab is offline
Old 09-05-2005, 02:19 AM
Leland Pate
User
Leland Pate's Avatar
Mine has it too. I don't know if there is an adjustment to be made or not. But... ...you are not alone.
Leland Pate is offline
Old 09-05-2005, 04:51 AM
mortod
User
mortod's Avatar
Me too - I was going to make the exact same post. In my case wear is turning to rust, so I am keen to find a solution.
mortod is offline
Old 09-05-2005, 10:23 AM
cabrio993
Super User
cabrio993's Avatar
I don't think there is an adjustment, but you may want to make sure that you have all your round rubber cushions in place and that there are not worn out. These fall out easily (ask me ..I know) and with age and heat they may have been compressed or too soft. If these rubber pieces are missing or colapsed, you'll get the friction you are describing.
Also, after you replace thos rubber feet, you could place some 3M tape on the friction points. This will prevent the paint from being removed and rust to develop.
cabrio993 is offline
Old 09-05-2005, 12:30 PM
mortod
User
mortod's Avatar
Good advice. Mine are all there. Do those rubber cushions have a part number, or are they non OEM - where can you buy them ? Or is it possible to just increase the height in some way without replacing ?
mortod is offline
Old 09-05-2005, 01:04 PM
993cab
User
Can someone describe where the factory cushions are located? i was also considering putting the rubber cushions, but where to find it?
993cab is offline
Old 09-05-2005, 02:51 PM
PK
PK's Avatar
Part #: 999 703 449 40
Upon second look, I think this is the rubber part you'll need.
I don't know its part number....
Maybe someone can help
PK is offline
Old 09-05-2005, 04:57 PM
mike cap
mike cap's Avatar
Cabrio's (Sergio's) suggestion is a good one. I think everyone has the paint rub marks to one extent or another. Make sure all the rubber bits and pieces are in place. I added pieces of "chafe tape" made by 3M to the wear areas. It is a 1/2" clear teflon film tape that is made for this purpose, used in different aviation applications. If anyone need some of this, PM me and I can put some on little spools and send it out.
mike cap is online now
Old 09-05-2005, 07:11 PM
polver
User
polver's Avatar
999 703 132 40 rubber buffer
polver is offline
Old 09-05-2005, 09:08 PM
Doc V.
User
Doc V.'s Avatar
Problems created by contact between the spoiler and the deck lid can be alleviated by adding or removing shims--or what are referred to as "liners" in the 993 Workshop Manual: "the distance between the rear spoiler and rear cover can be adjusted by fitting liners (up to 4 per side) between the [two spoiler] mounting plates and the rear cover." See Volume 5, Body, 66-1 through 66-7 of the Workshop Manual.
On two 993s, I made the corrective adjustment by removing liners, and in each case the wear--the scuffing of the paint--between the spoiler and the deck lid was stopped.
____________
PCA National Instructor
BMWCCA Certified Instructor
Skip Barber Racing School Multi-year Participant
Doc V. is offline
Old 09-05-2005, 11:48 PM
993cab
User
I jus checked, all my rubber stops are in place. the "liners" sound interesting and seems to be the corrective action. Any part #'s or pictures?
993cab is offline
Old 09-06-2005, 10:41 AM
cabrio993
Super User
cabrio993's Avatar
Has the car been in an accident? or have you had work done to your body panels? These "liners" are usually used at the factory to align the lid to the body or if the car was involved in an accident and the fit is no longer there.
Having to buy additional shims or "liners" and unmount/remount the lid to correct an issue with worn out rubber stops seems to much work for when there is an easier fix.
Old 09-06-2005, 10:48 PM
Doc V.
User
Doc V.'s Avatar
You'll find the liners on unmolested, accident-free 993s; they are what factory technicians use to establish a suitable distance between the spoiler and the deck lid. They are quite easy to remove.
____________
Doc V. is offline
Old 09-07-2005, 09:41 AM
mortod
User
mortod's Avatar
Please please advise where to look for these liners - I can't spot them.
mortod is offline
Old 09-07-2005, 04:05 PM
Janina993
User
Janina993's Avatar
there should be micro switch on the left side under the wing which stops wing when it's running up or down. You can adjust this micro switch from "limiting screw".
Janina993 is offline
Quick Reply: 993 Rear Spoiler Adjustment
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
