Starting Failure
Starting Failure
Went out to start her up and she just keeps turning over without firing and starting. Car has been running great and this is all-of-a sudden. Before i tow it to the dealer for diagnosis, is there a DIY checklist that I dont know of to trouble shoot this???
Addict & Guru
allill's suggestion is the first thing to check.
Read this: DME relay replacement @ p-car.com
1. Jiggle the relay &/or remove & reinsert it. Sometimes it's a bad contact.
2. Swap it w/a known good DME.
3. Still no start, move on to other areas.
Two things:
One, these guys are right...Definitely check the DME first (I have a spare if you can't wait until Monday...I'm not too far from Cos Cob). If that doesn't fix it...Then it's almost certainly the fuel pump, as I had the same symptoms a few months ago (on the *%$#$! Hutch River Parkway).
Two, (and to my horror), I noticed that my status has been relegated to the lowly "user" designation...
My two year membership has been duly renewed, as I think not being a member while using and benefitting from this forum is just not right. The goodwill and helpfulness found here is worth supporting, IMVHO.
Okay, enough of that. Back to our regular programming.
Addict & Guru
Originally Posted by Matt Davies
... I noticed that my status has been relegated to the lowly "user" designation...
You should buy a second one as spare to let in your glove box. Or carry the procedure on how to wire the relay plugs together to allow you to go back home when this will happen in the bushes.
here is what was said in another thread:
Well the 911 PW is the june 2004 issue. They show a picture of the relay socket holes to be bridged with paperclip. Place the paperclip between holes 30,87, and 87b of the socket if you have flat pin relay or 86,87, and 87b if you have a round pin relay. And they stress that ignition is off before doing it! If the relay was faulty, the engine should start!""
Fiskarflugen,
Glad you got that sorted easily. Cheech at Rennwerke is a good friend of mine and kicks the dealer's *** at all levels, not least of which, is he's open for parts on a Saturday!
And Dan,
(sigh), thanks for reminding me...
And Dan,
Fiskarflugen--you gotta love this place huh? I have a spare DME relay and a spare Window switch in my driver's door pocket in case the inevitable happens
Originally Posted by Mike in Switzerland
Hi
what's the window switch issue?
I was unaware of that.
Regards
Mike
Regards
Mike
