Starting Failure
Exactly as Craig Said--my driver switch failed when I was in South Carolina--glad I had it in the glovebox...buy it from Pelican or another place like that--cheap insurance indeed....
Originally Posted by Craig Huckins
Picture this, your'e in the middle of nowhere, you roll down your widow and it wont roll back up. If it starts to rain..... or you want to park securely you are out of luck if you don't have a spare switch. It's cheap insurance to pack a spare.
Don't forget that you have three windows switches. You could just swap with the one on the driver's door which drives the passenger window
starter not turning
Originally Posted by JasonAndreas
What model year do you have? Is the starter turning but the motor is not catching? Do you own a multimeter?
Could it be the starter motor? Does it fail without any warning? The battery is new.
Thanks for your help.
Perhaps you have been very unlucky and your new DME ralay has failed. That or the connections on the bottom of the fuse box board in which the DME relay sits have come loose. I have had that happen to me before and my Tiptronic kept stalling and misfiring.
