Rear spoiler doesn't work still!
Okay, the spoiler has been fixed thanks to the help of a generous rennlister. Grmnxtc (Clive) drove to my house and discovered the problem. Apparently when the prior owner had the V1 harwired in, they hooked into the spoiler power wire. While doing that they knocked out the pins that connect to the spoiler module and replaced them in random order. It's amazing my spoiler worked for as long as it did. Clive, wiring diagram in hand, figured this out, put the pins in correctly and voila, spoiler works! I can't tell you how much help Clive was for me today. If I would've taken my car into the dealer, they would have taken me for a ride. Clive, thanks for the help, I owe you one. As Chris says, is this a great place or what? Rennlist, what a resource and what great people!
Thanks again.
Thanks again.
Thanks.
I'm working with an owner that had the same problem - turns out the previous owner did the spoiler mod mentioned here
http://boman993.com/diy-spoiler-module-mod/
and didn't put the pins back correctly. Check your pinout against this:
1 - blank
2 - blank
3 - Blue green
4 - Yellow Green
5 - Brown
6 - Red
7 - Orange
8 - Green
9 - Green Red
10 - Green Black
11 - Brown Green
12 - White Red
as in this pic:
This is what he found which is incorrect.
1 - blank
2 - blank
3 - Blue green
4 - Yellow Green
5 - Brown
6 - Red
7 - Orange
8 - Green
9 - Green Red
10 - Green Black
11 - Brown Green
12 - White Red
as in this pic:
I don't want to start a new thread since my question is related.
My spoiler goes up and down at the correct speeds. The only thing weird about my spoiler operation is that the rear spoiler switch in the center console won't operate it. Do I just need a new switch? I have checked that it's plugged in.
Mornin all,
went through the thread since my rear spoiler doesn’t work, but have a different issue.
It won’t work with the button and it won’t work automatic at the right speed.
Previou ma owner had installed a turbo wing (btw Who wants it??)
i purchaed a used stock retractable spoiler (in good conditions) that the body shop (after painting it) plugged to a battery and worked!
Plugged to the car It didn’t!
Fuses are fine.
It looks as though something in the wiring is not working.
Anybody har similar issue?
Unfortunately with electrical I’m very very bad
Fuses are fine.
Mornin all,
Fuses are fine.
Fuses are fine.
I feel your pain.... electrical issues kick my butt too. It is only though these sites that I keep my head above water.
Good luck and keep up posted.
http://p-car.com/diy/tail/tailwarninglights.htm
Thank you all.
I've just tried to look under the passenger side.
I could see the plug (connected to nothing) but couldn't see any module to connect it to.
Damn.
In your experience is this part easily visible?
I really spent almost half an hour to look around, removed the glovebox door too hoping to gain more room but.......
I guess that until I solve this module issue, checking the harness block.
Is it possible that the car came out of the factory with the aerokit rear wing? in that case there was not mechanism needed. Well actually all the wiring (up to the trunk) is there.....
Is this module expensive?
Was hoping for an easy solution.....
Damn.
Very easy to see. Here is the part number.... 964 618 212 00.
And, here is a good thread that shows you what it looks like and where it is....
https://rennlist.com/forums/993-foru...ler-mod-3.html
THANK you all for responses.
I rechecked and I confirm the module isn’t there.
Im attaching a picture I took before.
So my plan is to buy the module and install it. If it doesn’t work I’ll check other threads I’ve see about the harness wires.
Ill keep you posted!
2 quick questions
- the module (rebuilt) costa 353.25$?? Thought it was not that expensive. I’ll check market place if anyone has a second hand one
- once I buy that do I have just to plug it right?
thanks you all again
2 quick questions
Yeah it's expensive and used isn't much cheaper. I had mine sent to Ruf in Germany so it activates at a higher speed btw. The USA version goes up and down way too much.
