993 Forum 1995-1998
Car veers slightly to the left under acceleration. HELP!
Old 08-05-2013, 09:20 PM
Magdaddy
Magdaddy's Avatar
motor mounts was my first thought, FWIW...If they look original, may be time for RS or Wevo.
Old 08-05-2013, 10:23 PM
993/907's Avatar
How old are the tires (in years), and how worn are they?
gordo
Old 08-05-2013, 11:11 PM
MarkD
MarkD's Avatar
Work your way from the ground up
Since tire pressures are good...
Alignment... And as said in 2005, be sure the shop has a KT tool
Old 08-06-2013, 06:49 PM
Jeff96-993
Jeff96-993's Avatar
Also, do the tire swap on the rears. You don't have to go far to know whether it's a tire issue.
When I bought my car it had the same problem. Turned out I had one rear tire that was 0.1 inch taller than the other. Replaced the rears, car drove perfect.
Old 10-11-2013, 02:41 AM
David Schiff
David Schiff's Avatar
i had a similar problem, was the left or right rear strut collapsing under accel.cnt recall which all the simple stuff was checked before. the Best suspension person I know of is in Castro valley, I had been there b4 and the diagnosed and fixed the problem. 97C2, i willtry to recall his name, but i know bay area folks know him, blocking on the name, K.... something i think
PM me if you need, will get it for you, but other R listers know of him and may chime.
Old 10-11-2013, 03:54 AM
Beretta
Beretta's Avatar
Do you have different brands on the front tires vs the back tires?
Old 10-11-2013, 12:11 PM
L23FPorsche
L23FPorsche's Avatar
I did find that one of the links in the rear suspension was lose. Also the tire on that side was worn considerably more than the other. After tightening that link, the car tracks straighter under acceleration but not yet normal.
Quick Reply: Car veers slightly to the left under acceleration. HELP!
