993 Weight loss progarm needed?
It would more difficult to shave a few pounds off my frame so what suggestions you guys have on reducing the weight on the 993 C4.
Oh, I should say that I have already dealt with the bypass, supercups and turbo wheels. So, what else?
I was going to start with removing the back seats, carpets etc. I know every bit helps. Oh, how much does the AC and bracket, etc weigh?
TIA, David
TIA, David
Thanks, I am looking at momo, recaro, sparco and corbeaus. The longest one way trips I would take would be about 4 to 5 hours, so total comfort is not a must.
Is there a brand or model to avoid all together?
What is your weight loss goal and are there certain amenities that you would like to retain?
I can tell you now that the carpet may not be worth the hassle unless you are going all out. A true PITA job.
King of Cool
But like Princeton said, how much are you willing to tear your car apart and what you think you still "need" (stereo, sunroof, a/c, rear seats)?
Changing seats is a good start, easy to do, easy to reverse, no "hacking" and saves a lot of weight.
I think the stock seats are crazy heavy. I run Sparco seats in the rally car and they saved abouit 50-70 lbs instantly. But they are non-adjustable types and are very light. On a 993 - that would mean loss of access to the rear seats.
Any seat with a tilt mechanism won't provide the mega weight savings due to the tilt mechanism itself.
For longer trips, consider a "Frame" racing seat as opposed to a shell seat. Frame seats have much more give and are therefore more comfy. I've spent 12-15 houirs in the rally car in total comfort.
RK
RK
I'm far from being as knowledgeable as many others out there, but I seem to recall reading something about up-grading the front and rear sway bars to thicker, but hollow versions??? Lighter and stronger at the same time???
Scott
Scott
I remember something recently regarding the big aluminum (?) hunks of metal behind the front & rear bumpers. Obviously, these are important if you have a boo-boo.... I was going to remove mine, but chickened out.
King of Cool
You still keet most of the intregity of the piece but it becomes lighter.
I'm also thinking cutting holes to the rear bumper, at least behind the licence plate so at track I'd have little more airflow (cooling).
I'm not sure about that though...
My aluminum inner bumpers and the associated shocks are long gone. They dont fit under my GT2 Evo front bumper or with all the harware I'm adding in the rear anyway.
I've noticed FVD sells aluminum replacements for the shocks that are just meant to crush. They also have carbon kevlar replacements for the big aluminum inner bumpers. Quite pricey tho.
what happens if you have to get the car towed from the rear if the frame is removed or cut?
Can I get seat with sliders that bolt to the floor, or I still need the floor bracket. I don't mind having the seat bolted to the floor , but for passenger side I may not be able to get away and would like access to the rear.
So, I will do away, with the spare, pump, jack, carpet and take out the rear seats and as much carpeting as possible. Now, is the insulation glue to the floor?
How much to convert to RS door panel and get manuel windows? thanks, guys...david
Most of the full shell type seats have side mount brackets that mate up to sliders that bolt to the floor supports. I have my Recaro SPG variants bolted directly on the side brackets to the floor. Some people think they are way too narrow for comfortable street driving tho.
The carpet is actually glued to the insulation and the insulation is then in turn glued to the floor. VERY labor intensive to remove. Removing the carpet and insulation was one of the top 3 worst jobs I've done on my car.
RS door panels are relatively cheap compared to other mods. A good company is AppBiz. I think Viperbob may be a dealer for these.
