993 Forum 1995-1998
Is your light switch knob lighted?
Old 03-07-2005, 09:57 AM
  #46
Caveman
Caveman's Avatar
Hi Guys,
I guess I know what I'll be doing for the next few weekends! I didn't quite understand the ignition light reference. Is there something different between my 1995 model and later cars as all I remember is a flat round plate around the ignition switch. I thought that's what the torch on the key was for!
Cheers,
David
Old 03-07-2005, 10:24 AM
  #47
mike cap
mike cap's Avatar
David,
Hi. This thread is mainly about the internally lit headlight switch.
On my '97, there is a small lamp and socket above the ignition switch, built into the fascia (how's that for UK lingo?) above the ignition switch. When you open the door and get in the car, this lamp stays on for a minute and "floods" the ignition area with enough light so you can insert the key.
I don't know if the '95's have this feature or not. Hey, be careful using that "torch" on the key ring, you'll burn the dash !!
Ciao,
Old 03-07-2005, 11:03 AM
  #48
Caveman
Caveman's Avatar
Hi Mike,
Don't "flame" my torch; you need all the light you can get with the headlights on my car!
Sounds like your car is different to mine. Perhaps it's a US thing? I've just got tasteful black plastic. Of course, I may have just missed it, hidden away under the ledge like they used to do with some of the other switches on the Carerra.
Cheers,
David
Old 03-07-2005, 01:30 PM
  #49
johnwelch
johnwelch's Avatar
David, my 95 does not have a light above the ignition switch, either. I suspect it was added in 96, or later. It is allegedly located in the underside of the dash above the ignition.
The black plate around the ignition switch is a different matter.
Old 03-07-2005, 01:53 PM
  #50
Arrwin
Arrwin's Avatar
I believe the light above the ignition switch were fitted on cars '97+. My '96 C4S does not have it.
Here's a link a few weeks back on this exact subject, which should explain everything.
Ignition Switch Light
Old 03-07-2005, 05:48 PM
  #51
Caveman
Caveman's Avatar
Thanks guys! I appreciate it.
Cheers,
David
Old 03-07-2005, 08:17 PM
  #52
lowblow
lowblow's Avatar
I replaced the bulb in my headlight switch but still no workie..... I tried to move the prongs on the inside of the switch to make a better connection but still nothing.
Any ideas?
mike
Old 03-07-2005, 08:39 PM
  #53
johnwelch
johnwelch's Avatar
I had to use an amazing amount of force to seat the bulb properly. Use a flat surface, like a pencil tip eraser, to push it in.
Old 03-07-2005, 10:48 PM
  #54
Edward
Addicted Specialist
Edward's Avatar
So let me get this straight: 4 pages of threads for a lamp on a switch??? Amazing the time you people spend on such things ...geeeze!!!
... so these bulbs are readily available at the dealer, right?
Edward
Old 03-07-2005, 10:49 PM
  #55
Bull
Bull's Avatar
Hey, give 'em a break! It is March!
Now, if this were July.......
Old 03-07-2005, 11:01 PM
  #56
lowblow
lowblow's Avatar
Pushed the bulb in hard enough to practically break it and still cannot get it to work.
I can't stand it when the simplest things don't work properly..
any other suggestions?
mike
Old 03-07-2005, 11:06 PM
  #57
mike cap
mike cap's Avatar
Edward
Bull's right, we got nothin else to do - up to our *** in snow. Let's see how long we can keep this thread going.
Old 03-07-2005, 11:30 PM
  #58
cabrio993
cabrio993's Avatar
So...since we are talking about bulbs...I noticed that on the center rear section where it says "porsche" there are 2 lights/reflectors that are towards the center, on the inside of the reverse lights... However, there are no bulbs there
Were they put there for "future" use? Or do I have a pair of bulbs more missing?
Old 03-07-2005, 11:32 PM
  #59
cabrio993
cabrio993's Avatar
mike
Do you know for a fact that it is a good bulb? I know it's new...but maybe it was DOA? You can probably test it with a 1.5 volt battery and a couple of cables.
Old 03-08-2005, 01:10 AM
  #60
grmnxtc
grmnxtc's Avatar
I think that's for the "Euro" version which has regulations mandating fixed rear fog lights (bright red!) so people don't try and kiss your a$$ in the fog!
I think p-car has a section on adding the necessary (though IIRC it's a bugger of a job!).
Oh, and related to the topic of this thread, I'm about to try an LED in place of the bulb....(my bulb was blown)
Clive.
Quick Reply: Is your light switch knob lighted?
