993 Forum 1995-1998
Do any of you guys run with spacers on your 993?
Old 01-21-2005, 09:54 AM
993 Guy
993 Guy's Avatar
Default Do any of you guys run with spacers on your 993?
I have a set of Techart 15mm spacers on the rear of my 993 and I love the way it brings the wheels out to the fenderwell. I'm planning on going with the M030/BHD setup very shortly and was curious if anyone uses spacers with that setup?
Oh and BTW, where is the best (and least expensive) place to pick up the gear for the suspension setup? I already tried searching, but it was hard to decifer the best vendor from multiple posts.
Thanks.
Old 01-21-2005, 10:12 AM
Monique
Monique's Avatar
Personally, I would never use spacers.
It moves the fulcrum outboard from your wheel bearings and distributes the load unevenly. I think of spacers as a safety hazard... though Porsche had some on the early 930's. But they were engineered to take the extra stress.
If Viken pipes in, I would bow to his knowledge...
Old 01-21-2005, 01:22 PM
Surj-993C2S
Surj-993C2S's Avatar
The C2S came on 17in Cup wheels with spacers from the factory. Mine still has the spacers on and has been lowered and corner balanced with no problems - although I am about to have 4mm taken off the spacers to move the rear wheels in as they are currently almost proud of the rear wheel arch...
Old 01-21-2005, 06:32 PM
albertofourie
8th Gear
albertofourie's Avatar
Default Wheel Spacers
When I bought my 993 it had spacers on the front and rear. My OPC advised to remove the front spacers as it is not recommended by Porsche and does effect handling. The rear spacers have remained as my OPC stated that it would not have any negative effect on handling/wear, are within Porsche specs and of course looks good.
Old 01-21-2005, 07:43 PM
TomF
TomF's Avatar
The spacers on the 930 were a bad idea too. The factory setup was so-so on my car, and when I went to aftermarket wheels and spacers, the car ate rear wheel bearings for lunch. The longevity of the rear bearing on those cars was directly related to the size of the spacer, the wheel offset and the contact patch of the tires. ...BTW, don't EVER use spacers that aren't hub-centric- this can be really dangerous!
Old 01-22-2005, 01:03 PM
riviera 93
riviera 93's Avatar
my car came with spacers on the rear "22mm" behind sport cup wheels. no problem 2 years at the track. e
Old 01-22-2005, 03:29 PM
TB993tt
TB993tt's Avatar
I currently run 27mm spacers with the 996tt wheels. My mind was put at rest by seeing a 700hp 993tt with spacers which has done over 235mph.
Quick Reply: Do any of you guys run with spacers on your 993?
