993 Forum 1995-1998
Help wiring new roof mounted 3rd brake light
Old 01-15-2005, 11:33 AM
smithk993
smithk993's Avatar
Default Help wiring new roof mounted 3rd brake light
I ordered an oem roof mounted 3rd brake light kit (Suncoast) for my early 95 coupe to go with my new Euro RS wing (MAShaw). I got the impression from a Porsche TSB that even the early 993 had the wiring ipre-nstalled for the top mounted light. When I pull back the weatherstripping at the top of the glass, I see a brown and black wire. I can't tell if they are connected to rear defroster or not. There seems to be the defroster tabs on the glass at the top as well.
Any one have any insights/wiring info? I hesitate to pull on these wires if they are actually connected to the defroster.
Thanks.
Keith
Old 01-15-2005, 12:46 PM
grmnxtc
grmnxtc's Avatar
Wiring diagram shows Black and Brown for the cabrio stop lights whilst for the defogger shows Brown, Red/black and red/white (3 wires).
Easiest way to tell... connect your voltmeter (or get a cheap one for $5 somewhere) and set it to measure 20V DC. Connect to the two wires in question and step on the brake! It should read ~12V when you do.
HTH,
Clive.
Quick Reply: Help wiring new roof mounted 3rd brake light
