Happy Holidays from Viperbob and Devek...
#35
Former Vendor
My wife just saw the picture of the brace and asked if it was a towel rack. BRILLIANT... What could be cooler than a carbon fiber towel rack? This would look great in any bathroom (and in my wife's case I'll probably save money over the fu-fu brand name towel rack). Maybe next, a carbon fiber toilet seat???
#37
Bilstein HDs with the extra 30mm.
Originally posted by viperbob
Father of 3 - These HDs are the standard US model and does not have the extra 30mm... Let me see if I can do something about that...
I would be interested in a set of HDs with the extra 30mm..... for my 96 993tt.
#38
#39
The RS shifter is not a straight fit as the angle of the shifter caused the shifter not to slide smoothly in. With a bit of dremeling of the opening to the tunnel (not necessary but made it a little easier for me), Bob's comment "Just shove it through with a hammer/jack!" and my trusty Sears alum jack, it went in and I was happily enjoying the shortened throw on the drive on Saturday.
Any pictures of the install or dimple you had to make?
#40
I actually took Bob's tunnel cover as he does not need it anymore so it was pre dimpled. I guess I could do a DIY day but there would have to be beer involved
Sorry, I dont have pics of the install but there are some on the p-car.com site and if you search for short shift... there are some additional hints.
BTW you do not have to remove the console. All you have to do is to remove the shift **** from above. All the rest of the work is done below.
#42
Originally Posted by StatmanDesigns
When do you need the extra 30mm of thread on the Bilstein HDs??? Please explain, thanks.
http://p-car.com/susfaq.html
in the section by Dan 96C2 St. Louis. he mentions the shortcomings of the regular HDs. Since Dan's post, Gert has come up w/ the HDs w/ additional lowering range.
#44
If you are changing your springs........Eibach,H&R,etc.........THIS will actually lower your car. The 30mm of extra thread on the shocks,is not needed.I am not sure if they help with RoW spring set-up.I am assuming the extra threads allow you to lower the car that extra 30mm.
#45
Providing beer is the easy part!
