I CAN'T BELIEVE IT!! My 4th rear glass in less than a year
Last Sunday, after great a day out at the annual Porsche Club of NSW concours, my rear glass shattered into a million bits in my driveway.
This is unbelievable after having 2 rear screens blow days after buying the car late last year.
Thank God, this is covered by a 2 year warranty from Porsche after parting with just under 2 grand to have tha last one fitted, and I am fairly sure of the cause but I am not happy with the fact that it is happening at all. I, like most expect better from such a highly regarded manufacturer.
My question is, Has this happened to anyone else anywhere else in the world or has someone done a voodoo thing to my car??
I may be able to claim some sort of record...
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
The car was in a small front accident in 2000, I got the details from the PO and spoke to the repairer who told me the car was not badly damaged.
It is all electrical, believe it or not.
The cause of the first 2 breakages was due to do the top mounted brake light taking power through the conductors in the glass, a known fault to Porsche Australia and I was told a common occurence for the 993 coupe, but this one had them puzzled because the light was wired up independently of the glass when they fitted it last year.
I am waiting for confirmation but I believe this breakage was caused by a crook joint where the rear window demister wires connect to the glass.
Pictures will follow but I just want to get this confirmed first.
Cheers
Cheers
Passed On
You have one of the "fat-body" cars? C4S or 993TT (guess not from your description)? I have heard of a few of these occurring and personally witnessed one; guy in a TT came up to one of our track driving events, stopped at our tech/registration area, got out of the car and closed the door (swung the door closed but I wouldn't say he slammed it). Rear window shattered into a million pieces.
Can't remember a cause but might have been due to a pressure pulse in the car when the door was rapidly closed on a window installation under a lot of stress.
Would suggest to anyone to look at the window corners (windshield and rear window). If they're cloudy, could be an indication of a high stress situation and potential window crack/shatter incident is upcoming.
I have read that shattering rear glass is not uncommon with the 95s because of the way Porsche mounted the rear window - which they changed in 96. The problem is supposed to be worse if you have 18" wheels. No word on a fix or work-around.
The new screen is now in stock and will be fitted tomorrow morning.
Retint on Friday and home for the weekend.
Woohoooo...
Wish these things weren't so fragile, I am worried it is going to happen again.
Woohoooo...
This was a known problem with the early cars and a tech bullitin was issued in connection with the fitting of a replacement rear screen - if your was fitted through a Porsche Centre then it should have been fitted correctly so it is a difficult one to understand why it has exploded. I believe this bullitin has been mentioned before on the forum - try a "search" for more details.
PJC
PJC
Originally Posted by Monique
You do not need heated windows in OZ ![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
I am in two minds, should I leave it connected and use it every day if I need it or not so if it is going to fail again it will do so before the warranty expires or do I disconnect it and just leave the mirrors connected, no power to the glass should eliminate the risk of this type of failure.
PJC
PJC
This failure was similar but in the demister connection.
So Do I hold the record???
There must be an alternative like some lightweight plexiglass or something that may be less likely to explode. I always try not to press too hard on the glass when cleaning it for fear of this happening to me!
I feel your pain. My rear glass arrived today from Germany. Set to have installed Monday.
Glenn
'96 993
Glenn
'96 993
Alan is correct, there is no TSB for the rear glass shattering, only installing third brake light, and one on paint corrosion repair.
for rear glass installation, the workshop manual is the only source I think
