clunk cluck clunk
clunk cluck clunk
I have this clunk sound that comes from what sounds like inside the dirvers side door...but their is nothing that is in there. Any suggestions on where to look or what might be the cause would be helpful. it truly sound like something is rolling around. Strange hugh??
I have the same sound too! I have been searching for weeks and I still can't pinpoint it. When I listen to the door, it sounds like it is coming from the rear fender. When I listen from the fender, it sounds like it is coming from the door. I am about to tear the car apart to find it! BTW, it doesn't make a noise when I turn left... it is almost like it settles in. When I turn right, it clunks. Turn Left (settles back in) Turn right (CLUNK).
If the middle sound is truly "cluck", I'd look around for a chicken in the door. Just kidding. No idea unless your crossover box under the arm rest has come loose from the cardboard backing. Have you removed the plastic liner and dug around in there?
I need to reach around behind the door panel and see what's up. My stereo is completely aftermarket-- which I installed--so I know there isn't anything like that going on.
