993 Forum 1995-1998
front tires wear
Old 08-31-2004, 02:56 PM
sptschoice
sptschoice's Avatar
Angry front tires wear
After lowering car front tires are wearing on inside...aligement was done but problem still exsit...any ideas?
Old 08-31-2004, 03:00 PM
adsc4s
adsc4s's Avatar
993s are usually set up with some negative camber. Because of this, your tires will wear on the inside first. Tell the alignment shop you are looking for maximum tire life and they should be able to tone down the negative camber.
Old 08-31-2004, 03:01 PM
ca993twin
ca993twin's Avatar
What front camber spec was used for your alignment? An agressive negative camber will cause inside edge wear with normal street driving. Just having an alignment "done" doesn't mean the car was set to your needs.
Old 08-31-2004, 11:49 PM
sptschoice
sptschoice's Avatar
thanks, I'll have them try to tone down the negative camber
Quick Reply: front tires wear
