Emergency/spare items for a 993 road trip
I seem to recall someone creating a list of emergency/spare items for a 911 to take on a long trip. Maybe Bruce Anderson put one together?
Those of you on the Mercedes club list will remember the one that George used to post quarterly.
I've been searching archives and the public Internet but cannot find these lists.
Does anyone have the 911 (or the Mercedes) list to post?
Thanks,
John
Thanks,
John
Lifetime Member
Lifetime Member
John,
I don't have an official list, but I would definitely bring the following:
Spare belts, couple cans of fix a flat, some variety of tools, especially ones that you can use to replace any broken belts on the road. Couple quarts of Mobil 1 oil, and couple of extra spark plugs.
That's what I can think of for now.
Passed On
Robin has a fairly good list. I might just add a selection of every fuse type/size, and a headlight bulb.
(note - what is a "long trip"? I am assuming 500 miles or more. Personally, I would leave the spark lugs at home - you probalby won't be able to change them on the road, and spark plugs nowadays are virtually trouble-free.)
Make sure that you have the wheel security lug nut. A couple of spare A23 batteries (part# 23-154 at Radio Shack) for the remote key device might come in handy, as well.
Haiku Grasshoppa
Can I Drove Your Car?
What to take on a long road trip?
1) Lots of cash.
2) cell phone.
3) One really good CD.
Why just have a road trip, when you can have an Adventure?
1) Lots of cash.
2) cell phone.
I agree with DJ but in Arizona, in the summer, several liters of water would be at the TOP of the list. You need the water to keep from becoming dehydrated if stuck.
Regards,
George
In sunny Arizona
Regards,
George
In sunny Arizona
Here's what I normaly carry for a long journey through back country roads:
1) Tools (not your entire tool cabinet)
2) Fix-it Flat (1 can)
3) Mechanic's glove (any kind of glove will do)
4) Bottled Water
5) Walkie-Talkie
6) Flashlight
7) Battery compact charger (disposable)
8) 2 ton portable floor jack
9) Extra t-shirts
10) No-water soap
11) Emergency belt
12) AAA+ card
Okay, sounds like a lot of stuff to carry in the trunk but they sure can come in handy.
Why the 'floor jack'? I thought it would be quicker if I need to remove the wheels.
Ron
'98 993
'99 M3
4) Bottled Water
5) Walkie-Talkie
6) Flashlight
9) Extra t-shirts
10) No-water soap
11) Emergency belt
12) AAA+ card
Ron
'98 993
'99 M3
John,
I would add road flares, or those reflective triangles, and detailed maps (if traveling to areas for first time) to the above list.
Important too is a pre-trip inspection, this can included checking belts for tension and wear, tires for possible nails, or cracks, fluids, and just overall look underneath for any fluid leaks.
Enjoy your travels.
Enjoy your travels.
Just a comment on one item that seems to be common on everyones list...
o Fix-a-flat
Please, please, don't use this stuff if you can avoid it - it may save you in an emergency, but the chemical compounds in it will ruin a tire prematurely. One tire expert I know pleaded with me when he found a bottle in the trunk of my old Acura...claiming that 2 out 3 tires that came through his shop that had had fix-a-flat used on them had to be replaced.
I learned how to temporarily patch a tire, and carry an air compressor with me...better than a $200 tire!
sean
o Fix-a-flat
sean
You’ve all forgotten the most important item: someone to keep you warm at night!
Actually, one must consider the climate. The example above is water when traveling in the desert; the opposite would be blankets or sleeping bags when traveling in the winter.
