Canepa 993 “4.0L RSR”
This was my favorite car at Rennsport. Some questions in case anybody has insider knowledge:
- is this a real RSR?
- is it intended to be streetable?
- did anybody get a good picture of the tachometer (I’m curious what the redline is)?
The following 3 users liked this post by Moriartyhlms:
not a real RSR, but the intake and catch can and blt drive looks to be oe 964 3.8RS or possibly 964/993 RSR, most likely tuned for street use( no roll bar or cage) still has cam driven p/s pump but no A/C
M. Schneider (10-02-2023)
I see a cage in there
That belt tensioner looks pretty dang close to the Clewett setup.
The following 3 users liked this post by 71-3.0-911:
Bill - do you know specifically how that catch can is plumbed to the oil tank and air intake? Also, do you know where that cloth-covered line from the catch can goes?
Unfortunately not, there are a a number of areas that are not well documented in the manuals , catch can is one
What do you call it then...6-pt metal tube decoration?
Antonov (10-17-2023)
You didn't answer the question.
That shown tubes you call a roll bar
to be specific, as shown in the certificate its named Einschweisskaefig, means welded cage.
Everything ells would be called 'Ueberrollbuegel', which means (see above) ... roll bar
The following 2 users liked this post by Holger3.2:
C4Spolar (10-05-2023),
M. Schneider (10-04-2023)
Fine...let's call it a 6pt roll bar then.
There's a roll bar in the car. Didn't think I had to spell it out for you people, but that was my point.
Originally Posted by Alan Smithee
Fine...let's call it a 6pt roll bar then.There's a roll bar in the car. Didn't think I had to spell it out for you people, but that was my point.
I didn't think I had to spell that out for you but here we are.
You're welcome.
