help with DAS rollbar install
Originally posted by KRA993tt
I did not rubber coat up in there as I think I still have dust from Germany up there. Not much gets up there.
Jamie,
I read what was going on on your other anti-sub thread. Just to clarify what I am doing is what the mfg. of the belts I have recommends. I am using Schroth 6-point belts with clip on ends. They depict the anti-sub belt coming from a point 20 degrees either side of a line (fore and aft) drawn straight down from the hole in the bottom of the seat.
"Never run the anti-submarining strap backwards. It is not designed to be a body restraint. It only helps to keep the lap belt in place during a crash to reduce the risk of submarining."
That is a quote from the instructions I got with this type of belt. I don't think the belts I have would even reach the lap belt mounting points.
Thanks for looking at the other thread Keith. I have decided to mount the sub belt through the floor like you did. Even if going through the side holes is ok I am not comforatble with the idea of the sub belt wrapping around my thighs to clip in. Also, coming up though the hole will be a cleaner install since I also want to keep the three point factory belts intact. Thanks again. I will be refrencing your pics for sure.
Jamie
Jamie
