View Poll Results: Interested in light weight 2pc rotors
Yes, I have the front and rear 2 pc
1
9.09%
Yes, I have the front from RB but can't find the rear
1
9.09%
If you make the rear I will puchase the car set
8
72.73%
No interest at all
1
9.09%
Voters: 11. You may not vote on this poll
Light Wt Two Piece Rotors for 993TT
Former Vendor
Front two piece: https://racingbrake.com/2520 (in stock)
Rear two piece: https://racingbrake.com/2495 Production pending due to rear drum brake constraint that requires pad modification.
Former Vendor
Our rear rotors always retain OE's drum brake (in blue) while Porsche owners seem to be more intelligent than other communities (eg. Jeep, Hellcat etc.) in the concern of the rear drum brakes.
However due to the rotor diameter is only 322mm so some pad modification may be required in order to accommodate the drum brake 180mm ID.
Although the design is up but since some customers may find it (pad mod.) unacceptable so the production is still pending.
Rear two piece rotors - Just for the weight saving?
See how it was replied by the owner of the brake company who produced those rear two piece rotors with aluminum hats.However due to the rotor diameter is only 322mm so some pad modification may be required in order to accommodate the drum brake 180mm ID.
I joined from the forum that "Racing"Brake cross-linked to ask this question:
Is it wise to trust one's life and property to a company that openly insults potential customers and doesn't respond to questions about the design or origin of its products? I think any track enthusiast regardless of the brand they drive would make the same decision.
Cheers!
Cheers!
HC.org (02-27-2021)
What kind of modification would be necessary? Relatively easy?
Cheers!
Cheers!
Former Vendor
Drawing showing tight space for hardware to accommodate between a drum brake (180mm) and a smaller rotor dia. (322mm) with OE pad depth, and the possible interference (in yellow) with brake pad bottom (outboard side).
Brake pad depth=51mm, so it may require to trim 2-3mm (Only outboard pads x2 need trimming) at the bottom to clear the hardware when the pad wears down.
Rear brake pad:
Rear brake pad:
If the 322x28 rears need a few mm shaved from the outboard pads, are the non-turbo 299x24 rears feasible or not? Shaving 2-3mm from the rear outboard pads wouldn't bother me a bit.
For what it's worth, I had my hydraulic brake boost (964 C4/turbo system) run out of pressure from a random bad connector wire at an autocross. No brake boost and the pedal was suddenly rock solid. The handbrake was the only thing that saved me from saying hi to a visit into the trees at 60mph. I think your approach of using an iron brake shoe liner, instead of just the aluminum hat inner diameter, is a winner.
Edit: for the record, I got these weights for OE rear rotors
16.2lbs 964 299x24
15.2lbs 968 M030 299x24, same as 964 except are "drilled"
14.2lbs 993 299x24 Meinle brand "drilled", 29.0mm shorter hat than 964 due to hub difference
16.2lbs 964 299x24
Former Vendor
For a 299mm rotor with OE drum brake retained your brake pad is constrained to (299-217)/2 =41mm, so if you can manage the pad depth to be @38mm the rotor can be made available.
Very valuable experience to share on the need of rear emergency brakes. In fact when we developed our composite rear hat (aluminum shell with iron sleeve insert) some 10 years ago, it was field tested by a Camaro SS G5 track driver running in COTA, he used only the rear drum brake (no foot brake) to slow down the car.
We are proud of this successful development which has helps hundreds of track enthusiasts shaves some 4-6 lbs per hat/rotor plus better heat dissipation vs. OE's stainless steel hats for CCB rotors and iron hats like Nissan GTR rear two piece rotors.
Make your rear CCM rotor lighter
https://www.corvetteforum.com/forums/c6-corvette-zr1-and-z06/3639696-make-your-rear-ccm-rotor-lighter.htmlLast edited by RacingBrake; 02-24-2021 at 05:35 PM.
https://www.corvetteforum.com/forums/c6-corvette-zr1-and-z06/3639696-make-your-rear-ccm-rotor-lighter.htmlTrimming the pads is not a problem.
Former Vendor
Good so it looks like trimming is not an issue for you guys although we still like to disclose it and make prospective buyers aware of the require modification.
If we can have 10 people sign up for pre-orders, we will provide a coupon code with 10% discount for you to per-order - Details will be announced later but for now add your vote to the poll.
Former Vendor
