Brake job
Brake job
So I finally ordered the parts to replace my brakes in my C4S. My question to you all is whether I should spend the money on the brake damper plates. They come to almost $250 cdn and I have heard from a few people they are not required. Would like to hear from those of you that have run with or without them! I ordered the textar pads. Car is a street car not tracked!
Thank you in advance!
Derek
Derek
I use them in conjunction with very soft street pads to minimize brake squeal. , however, you have some options. Some folks reuse the old ones and cement them to the pad backing plate with a little squeal silencer compound.
Also, RockAuto.com sells them under the URO brand if you want to replace them with new for substantially less than OE. Verify the sizes you need from the Porsche 993 parts catalog and if URO offers them in the sizes you need. The size reference is the piston size. I was able to get the sizes I needed for my base Carrera in the URO brand. I seem to recall the best way to install the noise suppressor clips/spiders is to;
Andy
- press them into the piston cups;
- peal off the adhesive cover sheet on each one and then;
- slip the pad into position
Andy
Andy
