Tank Ventilation Valve Fault Code
Hi guys,
I'm jusing the T-OBD Scantool which tells me my Mototronic has fault code "44 - Tank ventilation valve".
Is this the same as fault code as P0444?
If you go to the Factory service manual: DME Diagnosis "book #24" you will find a section that explains the error code 43 as well as the procedure to test the valve.
It is #3 in the picture below. Screen shots of the service manual sections as well.
Swallowtail (07-18-2019)
I have not tried it yet, but from what I remember both the durametric and the UDT999 OBD apps allows you to activate the valve as described as the "drive link" above.
- A 45 is a valid code derived from the conclusion that the CAT is not working properly, diagnosed by the after CAT oxygen sensor.
- A 93 is listed as "Fuel Tank Ventilation System P0441"
- A 98 is listed as Fuel Tank Ventilation Valve P0444 or P0445 or P0445
Am I missing something here?
Andy
For any given 2 digit fault code in combination with one of the below 4 states will point to one specific "P" code that relates to it.
0 MIL is not triggered with this fault
1 MIL is on and Freeze Frame is stored in memory
2 MIL is on and a previous Freeze Frame is overridden
3 MIL is blinking and a previous Freeze Frame is overriddenIL Light and memory status states:
Andy
Here it is:
I must be missing something in that I do not show 43 as a valid code on my factory-supplied document dated 1996 named "On-Board Diagnosis 911 Carrera (993) Trouble Codes". It is listed as a valid Porsche Code on a third party site but possibly not for a 993.
Here it is:
Here it is:
I checked the lists they don't match in some descriptions for the same numbers that are on both lists:
Maybe the earlier non-Varioram non-OBDCII Motronic ECU has a completely different code set that was changed and remapped to meet the 1996 USA DOT/EPA OBDCII standard code list required by US Regulation.
Andy
