SAI port cleanout
SAI port cleanout
I'm planning to use the bicycle brake cable method to clean out the SAI ports by the exhaust valve. About how long a cable do I need? How far up the port will the cable go before reaching an obstruction. Has anyone tried to take out the check valve on the top of the motor and run the cable thru that way?
All help much appreciated
JC 98 C2S widebody
JC 98 C2S widebody
JC 98 C2S widebody
JC 98 C2S widebody
Remember this is just a temporary fix, may last a few years depending on how bad you guides are.
Before you go to all this trouble be aware that the Motronic controller identifies clogged air injector passages indirectly via information from the oxygen sensors.
If one or more of your sensors is out of specification it may be contributing to an erroneous diagnostic code,
Due to the difficulty in cleaning the ports, I would first replace both oxygen sensors on the side of the engine listed by the fault code, bank 1 or bank 2 and replace the air pump check valve and see if the code comes back. Also if you used Durametric to diagnose the system make sure you are using the latest software version. I go to the extra step and validate what Durametric is reporting with a 2nd handheld reader as Durametric has proven to produce erroneous codes in combination with non-existent codes at times due to communication errors with the ECU.
Andy
Andy
Andy
Interesting question, for an added data point I got the clogged OBD Code for bank 1 at about 95,000 miles and replaced the oxygen sensors, the check valve and updated Durametric to the latest software and the code never returned, go figure?
I did this 2 years ago and the ports were completely clean- no carbon anywhere in the system or on the valves- but the check valve was really dirty. We replaced it and did the whole flush thing to be certain and all ports ran clean- so you may not have a clogged port- might just be the valve. Just sayin'. My car had 110K on it when we did this.
The car has 61K miles and is driven regularly. I can test to see if the ports are open by observing the O2 sensors with my OBD software. When I trigger the pump, the O2 sensors react as they should so i know that some or all of the ports are open. I replaced the check valve when I first got the car 12 years ago and it only has about 20K miles on it. The problem has continued all of those years and I'm careful not to overfill when changing/adding oil. I'm guessing that any clogging would be close to the port in the head since that's where the excess oil from overfilling or valve guide that is burned would begin to collect. I want to check the ports because I continue to set SAI CEL's. If I let the engine idle for 2 minutes after start up to the end of the SAI cycle, it will not set a code. If I start up and drive away immediately, a SAI CEL will be set for one or both sides 90% of the time. I want to clean out the ports to eliminate any possiblities. I changed all 4 O2 sensors awhile back and the problem diminished, but didn't disappear. Now it's back with greater frequency.
Talking with another Pcar owner and he suggested an old speedometer cable? It's a little thicker and should be flexible. Yea or nay on this idea? Just wondering.
Thanks for the info to all that replied.
JC
98 C2S widebody
JC
98 C2S widebody
I had a Bass Guitar string- LOL! Didn't end up using it tho. Also, there's a little vacuum tube by the SAI valve- I knocked mine loose when I did the change-out and it was throwing the code after the blow-out. I replaced it and no more codes- check to see if it's come loose.... may be the only issue.
Replace the valve, or continue to look for love in the wrong place, you will find her and she will be an expensive and unsatisfying date, Hey, it's your money time and effort!
Andy
JC
98 C2S widebody
JC
98 C2S widebody
Your description sounds a lot like lazy/aged O2 sensors, but since you changed them recently, did you replace the SAI check valve?
I changed it when I first bought the car 12yrs ago and it has about 17K miles on it. I will remove it and check to see if it needs cleaning/replacing.
Thanks for your input
JC 98 C2S widebody
JC 98 C2S widebody
