Alarm key fob program problem.
1996 C4S 36k miles.
I have two keys and fobs, of which only one of the fobs work.
The car unlocks and locks as expected and starts every time as long as you don't let it sit for long enough for the immobilizer to engage. All normal.
The LED's in the doors blink as expected, initially fast and then slow if everything is buttoned up, double blinks if the frunk is open a crack for the trickle charger.
I went to my local Porsche dealer and got the code to program the other fob.
When I unlock, lock, unlock the car with the key to start the procedure I get the initial horn honk on the first unlock BUT.....
..on the second unlock the hazard lights blink for a few seconds and then the alarms goes off. I can only turn off the alarm with the fob.
I am also not getting the immobilizer light in the clock so I can't program the other remote. This is true regardless of whether i open the doors with the key or the fob.
There is a bulb missing from the frunk which I ordered and the rear deck doesn't seem to have a light at all as it's been modified for an aftermarket wing which I'm currently replacing. The OEM turbo S wing that will go in it's place also doesn't have a light. Maybe the light is in the car and not on the deck, must dig around a bit.
Any help would be appreciated.
G
G
Your issues are exactly as you suspect. You have open grounds in the frunk and the missing engine bay light.
On the same circuit, are the interior lights, the door micro switches, glove box, and clutch micro switches.
See attached.
Andy
Even if I open my door with the fob, I still don't get an immobilizer light in the clock even though the alarm appears to be working so I can't even start the procedure.
G
G
If it doesn't then the little bulb is blown out or its socket needs cleaning or in some cases the clock needs to be pulled out, opened up and the solder joints on the circuit board in the clock need to be reheated as a solder joint has come loose, This is a known issue and a kitchen table DIY project involving a soldering iron to fix.
The sheet says unlock the cars with the fob and sit in it with the door closed. Does the alarm not turn on and the doors lock after 2 minutes or is that not the case when the key is in the car?
G
G
FWIW, one of my previous 993s was a C4S with an aftermarket Turbo S fixed wing ( no light). The original connector to the original deck lid was simply disconnected with no pins jumped regarding the missing light. The immobilizer worked as normal. I then replaced the fixed wing with the original motorized decklid, and the connectors were reattached. No issues.
BTW if you currently have a fixed wing, is the spoiler module under glovebox disconnected?
G.
Posted a couple photos of my engine lid light to your other post.
Glenn
Glenn
The "automatic lock after 2 minutes" only happens if the door isn't opened following the FOB unlock. It's designed that way to prevent locking the key in the car.
BTW, a few months back I also had difficulty programming a second FOB. My immobilizer light worked ok, it just didn't flash the way it was supposed to during programming procedure. I discovered this after viewing a video that ECU Docs posted of the procedure where you could see the immobilizer light in the background. I ended up sending the immobilizer and FOBS to ECU Docs to program, which they did.
Know soon.
G
