Converting AWD to RWD - definitive parts list here - Updated
Since a few people have asked, I found the records from when I converted the 4S to RWD.
I'll PDF and post up the documents once I get access to a printer that PDF's. Craig Updated 10 Jun 2019 Below is the parts list needed https://cimg3.ibsrv.net/gimg/rennlis...ed20ae55cd.jpg You'll also need two ABS ring sensors P/N 99334111501, two bolts 90008212309 and 2 nuts 99908463409 (See Viper Bob process referenced below) Below is a photo of these parts. What you can't see in the upper top corners are the toothed rings that keep the ABS sensors happy and the fasteners that hold them in place (these substitute for the front drive axles. https://cimg9.ibsrv.net/gimg/rennlis...b26014e6cb.jpg Below is the front page of a most helpful conversion process document created by Viper Bob. It is copyrighted material, so I WILL NOT post the entire document. Contact Viper Bob https://cimg6.ibsrv.net/gimg/rennlis...cfcf49b8c3.jpg The conversion process was straight-forward. If you can do a brake job, you can probably do this. A few learnings?
Have fun. your car will lose about 120 pounds, gain some rear drive playfulness AND you have more tyre diameter options. Mark DiPietro of FD MotorSports (formerly????) was a big help in sourcing parts. Craig |
Need this! Thx
what about putting fd golden rod and shifter at the same time? Do you have to buy the awd or now the 2wd version? |
updated
the entire parts list for the shifting mechanism can be replaced by the CAE ultra shifter
Originally Posted by cgfen
(Post 15894469)
https://cimg3.ibsrv.net/gimg/rennlis...ed20ae55cd.jpg |
Originally Posted by Paseb
(Post 15895907)
Need this! Thx
what about putting fd golden rod and shifter at the same time? Do you have to buy the awd or now the 2wd version? 2WD version of both, great time to do them. The FD AWD transmission mount is a nice addition as well to help firm things up since you'll be RWD only without the center trans mount.
Originally Posted by k722070
(Post 15898641)
Thanks for sharing!
