Short shifter
Short shifter
Looking for a shifter that will shorten throws and tighten shift feel while hopefully using my stock shift **** and boot. Rothsport doesn’t appear to retain the factory look. Any recommendations?
The SSK is, I believe a Rothsport part (someone correct me if I’m wrong, but it doesn’t use the billet shift **** like the other Rothsport short shift kit that you’re referring to.
Thanks so then were you able to retain your oem shift **** and boot?
Rothsport makes both:
New **** — https://www.rothsport.com/Products/T...et-Shifter.htm
Re-usable with current **** — https://www.rothsport.com/Products/T...rt-Shifter.htm
Just added FD SSK and Golden Rod to my C4S. Uses original shift boot. No change in look. Good upgrade esp. improved feeling of precision. Not super short throws however. But I really like it a lot.
FD!!!!!!
Fitted one recently. Really like, GR and SSK work well together, it is a very noticeable mod.
Review:
http://aircooledbug.co.uk/fd-motorsp...ort-shift-kit/
Review:
I also installed FDMotorsports short shift kit and golden rod. Very nice upgrade! Call and talk to Darrin and he will answer any questions you have but their website has photos and schematics of the install.
I later added a function first shift **** using my original boot.
