993 Forum 1995-1998
Fog light alternatives
Old 05-17-2019, 03:43 PM
nowata
nowata's Avatar
Default Fog light alternatives
Ah yes the gravel pit strikes again. I had a nice chunk fall from a truck and took out my driver side fog light.
Do i replace it or take this opportunity to ditch the bumperettes and install the much better looking IMO air inlets? Do the air inlets adversely impact value? My car is nice but it's no virgin (been repainted). I believe they require some cutting of the bumper behind the inlets regardless of what the air feeds. Suggestions or product links appreciated.
Old 05-17-2019, 03:53 PM
Kika
Kika's Avatar
I installed ducts, which I had to modify slightly, as they are designed to be used with euro bumbers, and not US bumperettes.
by modify slightly, I mean, used a dremel to shave off the corner, which would have obstructed where the bumperette connects. The S style ducts with the round light are quite popular as well. Since I do mainly city driving, I have little need for fog lights, and also with HIDs, I get all the light I need out of the headlights.
I vote to remove the bumperettes and go with ducts, either with or without the lights depending on your preference/need. It is all removable back to original anyway, so I don't thinkl value is adversely affected at all. No cutting, but you do need to fill the hole where the bumperettes go. (I would think it is actually preferred and therefore a plus up on the cost.)
Old 05-17-2019, 04:00 PM
nowata
nowata's Avatar
Thanks for the reply. From what i've seen it looks like my amber light does't wrap far enough around the front to meet the air duct.
i'd probably go this route
https://www.fvd.net/us-en/FVD100111/...c-cooling.html
or this route if i decide to keep the lights. i kind of like the no-light look better.
https://www.fvd.net/us-en/FVD631980/...ng-lights.html
think either would work? Maybe i need to ditch the ambers a go clear anyway.
Old 05-17-2019, 04:07 PM
Kika
Kika's Avatar
You can purchase Euro side markers, that meet up with the fog/duct.
I didn't realize you have a black car. I also have a black C2, so the bumperettes don't really bother me that much. At the end of the day it is up to you.
I got the air inlets without the lights from FVD, decent product, the part number is FVD 100 111, they were only $99 when I got mine!
https://rennlist.com/forums/993-forum/918409-what-did-you-do-with-your-993-today.html#post13508102 post #220
Old 05-17-2019, 04:20 PM
goofballdeluxe
goofballdeluxe's Avatar
When I decided to respray my front bumper due to rock chips, I figured that was the time to get rid of the bumperettes and go with OEM Turbo S ducts that I purchased from Gert over at Carnewal. Although I think the ducts can be made to provide front brake cooling, mine are poser for looks alone and the LEDs function as daytime running lights.
I doubt it detracts at all from value, and since most don't like the bumperettes, might even result in a minor bump in value to those like-minded.
Old 05-17-2019, 11:00 PM
nowata
nowata's Avatar
https://rennlist.com/forums/showthread.php?p=13508102 post #220
Your car looks good
thanks for the tip
i have too many car expenses going lately with a frame off Austin Healey restoration taking place and don’t need to spend a grand filling bumperette holes
Old 05-17-2019, 11:46 PM
AOW162435
Seared
AOW162435's Avatar
I purchased a set of made-in-Austria Cult-Werk ducts from FVD three years ago. The ducts are molded plastic and required minimal prep before I primed, painted & cleared them. Very light and fit nicely - as opposed to the saggy Better Bodies ducts I had years ago.
Andreas
Old 05-18-2019, 11:28 AM
territory145
territory145's Avatar
Default Air Ducts
Hi everyone, Looking for a pair of Cooling Air Ducts w/ Fog Headlamp #993 631 980 00.
If anyone has a set that they would like to sell I'm in the market. I have a black car but any color will do.
Thanks,
Mitch
Old 05-18-2019, 11:47 AM
nowata
nowata's Avatar
Originally Posted by AOW162435
Andreas
I ordered these from fvd and will keep my bumperettes
Not up for a bumper skin graft at this time
are you you the guy in EC who makes art from Porsche parts?
Old 05-18-2019, 01:58 PM
territory145
Nope, not that guy.
Old 05-18-2019, 02:37 PM
AOW162435
Seared
AOW162435's Avatar
I may be that guy.
Andreas
Old 05-19-2019, 05:24 AM
911PERVY
911PERVY's Avatar
The FVD price of the turbo S ducts is wrong, they are well over $500 a pair
Many members on here have these;
https://www.ebay.co.uk/itm/Porsche-9...gAAOSw~IFbsJhL
Great value for money
Old 05-19-2019, 10:01 AM
territory145
Default ducts
Thanks 911pervy, I'll order these today!
Mitch
Old 05-21-2019, 04:50 PM
bart1
bart1's Avatar
I have the same setup as goofballdeluxe. Clear markers, bumperette delete, factory ducts and added some superbrightleds inside the lights (don't work for night time visibility). I like it overall.
Old 05-23-2019, 10:21 AM
kingroon
kingroon's Avatar
I faced a similar decision recently, although the damage was not as severe.. I went with restoring the Units..
Original Unit..
Glass removed, clean with strong cleaner.. I used Acetone..
Spray to Silver of choice; I went with Polar Silver to match the Bodywork.. Mask off the channels that the Glass will sit in..
All done..!
Don't be shy, but don't flood the channels either, the Glass has to want to stay put..
Paint Dry, ready for Glass
Installed..
Quick Reply: Fog light alternatives
