Power steering rack
Power steering rack
So just got my car back from an oil change and the service centre mentioned to me that my power steering rack was developing a small leak. Just looked on pelican parts to see what the damage would be and holy ****! $4600 for a rebuilt rack. I knew these were pricey but didn't think they were this expensive. Does anyone have any thoughts to an alternative place I can get a rebuilt rack at a lower price?
Thanks in advance!
Derek
Thanks in advance!
Derek
I'd suggest something like this and find a local shop willing to help you out if you're not comfy doing it yourself.
http://www.klaindustries.net/993rack/993rack.htm
I bought a second hand rack on Ebay and then sent it to a place in the UK to rebuild for about $350 with return shipping. I had that installed in my car and then rebuilt that rack also and sold it to another member to help offset the cost of the install.
Can't remember the place in the UK and I'm on the road so I can't look at my records but I got the name from the forums.
G
G
Thanks in advance!
Derek
Thanks in advance!
Derek
Porsche branded remanufactured steering rack with 2 year warranty is crazy expensive. Cheapest I could find is in the $3k range. I have no one locally who can rebuild a rack, so I sucked it up and bought it. Maybe that was stupid, but I just wanted to get it over with. I was a little leary of buying an off the shelf rebuilt rack from someone else. At least with the Porsche unit, I have the warranty and the warm and fuzzy of an "OEM" part.
On the plus side - the new rack works great!
Just Had my 1995 993 rack rebuilt several weeks ago, low price, professional quick service. RACK DOCTOR, South Carolina, info@rackdoctor.net, 843-558-7225
A small leak is nothing to worry about. If you find it dripping on the floor and topping off the reservoir regularly that is a different matter.
The hardest part is taking the rack out and putting it back in. Some rebuild their own racks others send it out for rebuild:
Replacing your rack
Good luck with this,
Andy
- If you rebuild your own rack it cost $75
- If you have someone else do it a few hundred dollars
- If you buy a rebuilt rack it will be over a thousand dollars and the durability of the rack is dependent on the quality of the core used
- If you let someone else pull it out and put it back in add a few hundred more to the cost
Replacing your rack
Andy
GD993C4 (01-18-2023)
I would monitor the leak for now unless it’s dripping all over the floor. To be honest I’ve seen some cars have a small leak or sweat for years without any issues.
I rebuilt mine myself. I purchased the KLA INDUSTRIES kit and downloaded a step by step diy I found on pelican parts (I believe) A New Zealand kiwi did a awesome job with the step by step. Color pictures instructions the whole nine. Probably the best internet step by step I have ever seen. Anyways it was actually pretty easy. That said I was interrupted several times by wife and kids and ended up skipping a step and had to pull the rack and fix my mistake. Basically if you have the time and facilities ( I used my standard two car garage and quick jack) the best option hands down is to DIY THE JOB yourself with the kla kit. However I have seen several race cars (993’s) that simply removed the pump and lines and ran the car without the hydro assist. So if the leak is small and not overly burdensome than you can just run it.
Thanks again!
Derek
Good to here. In my case I t was blowing the fluid out as fast as I put it in. Like stated by others it made a huge mess under the car. There was fluid from front to back under the car. However it didn’t leak much when park just when turning the wheel while driving. It would fill the tie rod boots and squish out when the boot was compressed blowing down the underside. Of the car. My ocd wouldn’t allow me to ignore it and the cost to replace was ridiculous. I called a local shop in town (web sight was still up advertising rack repairs) they laughed said they quit doing rebuilds a long time ago. They just haven’t been able to update there site. Apparently with most cars now days having electric or manual racks these older hydro assist are not profitable enough for a lot shops to mess with rebuilding. I took it as an opportunity to expand my mechanical skill sets and set about doing it myself. Honestly getting the darn thing out of the car was way more time consuming and frustrating than anything. I spent way longer on the removal and replace then I did the rebuild itself.
Steering rack options
Are Vertex and Steering Gear Super Store the only (reasonably priced) options out there? My indie recommends the former. Can anyone share their experience with Steering Gear, or recommend a better alternative? This is an expensive item (with labor), and I want to get it right first time.
Thanks!
Thanks!
Thanks!
Thanks!
I’ve heard of Vertex, never heard of the former.
