993 Forum 1995-1998
QUESTION - CDR220 shuts off
Old 03-19-2019, 01:28 PM
e9stibi
e9stibi's Avatar
Default QUESTION - CDR220 shuts off
I have a question about my CDR220 that I am using in my Cabrio for more than a decade. This is a low mileage car and I noticed a couple of months ago that the unit starts operating normally and when I drive a short time (~ 1 minute) the unit shuts off completely and cannot be restarted while driving by using the "on button". When I stop and turn the ignition off, the unit starts again as it is supposed to start and shuts off again after a short time. I ws able to replicate this behavior a couple of times.
Have you seen this before? Any guidance on how to trouble shoot?
Old 03-20-2019, 02:06 PM
nsully
nsully's Avatar
Does that unit have a removable faceplate?
If so, it may just be a matter of snapping it off and back on for improved contact.
Old 03-20-2019, 02:55 PM
pp000830
pp000830's Avatar
Received 1,448 Likes on 1,020 Posts
First, pull the radio out a little and check the plug and grounding strap.
Some units have internal protection against speaker short circuits. If your speakers are the original 20-year-old ones I would check their impedance.
Also to be reasonable the radios in our cars if original are 20 years old and may have dried out or failed internal components as well.
Old 03-20-2019, 06:22 PM
e9stibi
e9stibi's Avatar
Thanks for responses. Yes, it has the face plate but I took it on and off which did not impact the behavior. I have upgrade the system 10 years ago and have "new" speakers. At the end, I have to pull the unit as suggested and check the connections. I can than make measurements at the plug to see if the proper voltage is at the plug. This should allow to identify if the supply / cables are the issue or if there is something with the unit. Thanks again for help and I will keep you posted with my findings. In addition, I want to upgrade the unit to bluetooth with the new Becker kit:
https://www.ebay.com/itm/1999-02-Por...AAAOSw4CFYzARs
Old 03-20-2019, 06:59 PM
badabing
badabing's Avatar
You could try sending the unit to Becker Auto Sound in NJ. Experts in these units and reasonably priced.
Old 03-20-2019, 07:12 PM
mike cap
mike cap's Avatar
Becker can do the BT mod internally to your radio or should be able to. They just did my CR 210. See my recent new topic post. The mod is invisible.
You can pull your radio if you have the two keys and check the connections and maybe try some contact cleaner. But it sounds like you have a component failing or shorting out after being energized for a minute or so. Send to Becker with their on line form telling them the problem. They are good to deal with.
Quick Reply: QUESTION - CDR220 shuts off
