C4S stock ride height and springs?
I'm looking at eventually upgrading my struts - looking at the Bilstein B8 vs B6XT right now.
My understanding is that the C4S comes stock with Turbo suspension - thus it should be 30mm lower than a standard Carrera?
My car looks like it's lower and has less wheel gap than what I've seen in C2 pics, so I assume this is true. I've been looking through the archives and keep seeing conflicting information - ie "all US 993s have the same ride height".
I believe the C4S then came stock with M033 springs? Some insight appreciated - there is a lot less dedicated C4S info out there.
Pic for reference...
See the attached chart
If your car is lower then a previous owner installed different springs.
Hopefully these before and after photos upload.
C4S ride height as purchased.
C4S ride height after installing Bilsteinns with M030 suspension.
Ok that settles that then.
I’ll see if I can make out the markings on the springs and see if ROW springs were installed. Without seeing the car side by side with a stock 993 it’s hard to tell from pics.
Thanks guys for the pics. I couldn't tell any markings on the springs. But looking at these pics and comparing, I'm thinking this is ROW ride height.
From the chart I provided above one can simply measure the height at the designated measurement points with a ruler front & back and conclusively know where their ride height falls.
Enlighten me.
Car is definitely lowered. I don't think it's ROW m030/m033 based on my measurements, so I need new springs. For now, considering the m030/B8 route, as much for cost as anything else right now. Thanks for the help...
That chart is interesting. If I'm reading it correctly the column that shows deviation from stock indicates that there is absolutely no difference in ride height between US M030 and US stock suspensions. To get the 30mm reduction, you need the ROW M030 suspension. I need to stop just discussing M030 and instead refer to mine as ROW M030.
