OZ Challenge 18” 11j rear
I am considering to install then following wheels:
front 18” 8,5J ET 50 which I am sure it fits perfectly
rear 18” 11J ET 63 that I am not sure at all it would fit
1 inch (or 2,54 cm) more, split in two parts, 1,07cm in the inner side and 1,47cm in the outer part...now I have 7mm spacers with 18 inch ET65, but I think the only way it can fit the wheel compartment is adding some camber, isn’t it?
I think this might be the wheel set installed on the CUP car, with 235/40 in the front and 275/35 in the rear
Thank you very much Bill, your knowledge is as insuperable as precious!
For future use
on the left is what many of use on a lowered track type n/b 993 on the right is what a 993Cup would have used, tyres for the Cup would have been racing slicks equivalent modern Hi Perf rubber is used for both
