Question about SAI delete on 95
I deleted my SAI system awhile back, using the Patrick Motorsports plugs. At the time I failed to notice that when you remove the SAI system, it leaves an open hole in the bottom corner of the back of the air box where there is a spigot that used to connect to the SAI pump inlet hose.
What's typically used to cleanly plug this hole? |
Yes. Which is to say... anything. RTV, epoxy, silicone, silly putty, whatever you got. You'll never see it, so don't overthink it. |
Originally Posted by Top-Gun
(Post 15632597)
What's typically used to cleanly plug this hole? on my list, i would like to delete my Sai system on my 95 also, diy job? |
(Post 15632597)
Originally Posted by DutchNy
(Post 15632898)
diy job?
Andreas |
Originally Posted by AOW162435
A Yakima roof bar end cap is a perfect fit :)Yep. I deleted mine ten years ago and have done the same to 3 or 4 other 993s over the years. Andreas Thanks Robb |
Originally Posted by rcropp1
(Post 15633240)
Andreas - what's the advantage to deleting the SAI on our '95's?
Thanks Robb |
For those who haven't searched here are two DIY's on this
http://www.rennsportkc.com/1995-993-sai-system-removal/ https://rennlist.com/forums/993-foru...l-success.html TBH I have tried to follow both and literally am awaiting Andreas to stop on by to smack me upside the head and show me what I am doing wrong (partially deleted SAI here). Hope someone can use either one of these and make more sense.... Best, Paul |
Originally Posted by paulkromz
(Post 15633384)
https://cimg5.ibsrv.net/gimg/rennlis...ca951de57.jpeg Andreas |
truth is.... i miss your man musk :crying:
