Disadvantage of 964 Windshield in a 993?
I have read many threats on the topic of using a 964 windshield in a 993 and I know that the Cup cars came with 964 windshields. However I have one question that I can't seem to find any information on.
Are there any disadvantages to using a 964 windshield in 993? Thanks Robb |
Never heard of a 964 ws fitting a 993. Aren’t the 964’s held with rubber gaskets like the 993 quarter windows? The 993’s are adhesive secured. |
Can't work as the apertures are a different size. The 964 had a bigger hole for the rubber surround and as said the 993 smaller as it's bonded. When 9M did my sunroof delete the factory sent the wrong roof (it had a 964 aperture). The scuttles are also different. It had a 993 part no, 993 scuttle, but a 964 hole. 3 month wait for the correct roof skin.
So unless you trim the metal back it won't fit. |
Originally Posted by Endoman
(Post 15627653)
Can't work as the apertures are a different size. The 964 had a bigger hole for the rubber surround and as said the 993 smaller as it's bonded. When 9M did my sunroof delete the factory sent the wrong roof (it had a 964 aperture). The scuttles are also different. It was had a 993 part no, 993 scuttle, but a 964 hole. 3 month wait for the correct roof skin.
I was curious about this as well, as I wanted to try 964 rear glass in my car. I need to pull my rear screen to get after some corrosion starting in the corners.
Using the 964 screen has two big advantages, one being the ability to remove and install the glass myself, and the second being it doesn't have the stupid plastic trim that deteriorates rending the entire screen garbage. Unfortunatley I was told it wont work. |
Originally Posted by Top-Gun
(Post 15627808)
Originally Posted by mike cap
(Post 15627608)
Anything can be made to fit..............................................:to_order:
All the 993 widescreen part numbers begin with "993..." suggesting that they are model specific and the earlier ones won't work.
To be fair, a lot of updated parts will fit our cars in spite the part number prefix. For instance, the clutch fork I just bought is a 997 prefix, the disk a 996, working between a 964 flywheel and 993 gearbox.
Originally Posted by pp000830
(Post 15628605)
Originally Posted by ed devinney
(Post 15628689)
Andy |
Auto glass set in a gasket requires pretty tight tolerances on aperature size, you want it tight enough that the glass is secure but leaving enough room to actually get the glass in (via rope or similar).
If there were any differences in the dimensions of the aperature between 964 and 993, it wouldnt work. Sounds like this is the case for the front anyways. |
Originally Posted by Railmaster.
(Post 15628711)
The 964 screen may fit the 993 if it is fitted with the 964 rubber!
I would give back-dating the glass mount a no for these reasons. Andy |
The width of the window frame lip on a 993 is wider than the earlier cars(real life experience, I didn't read that on the internet). I have seen a lot more rust in window corners of early cars than 993s, not sure it would be worth the effort to back date your 993 to a noisy, potentially leaky seal.
