Does Mahle make a 102mm (3.8) piston/cylinder kit that uses stock rods?
Anyone know why the only 3.8 p/c kit for sale seems to be the RSR that requires a rod change as well? What's the reason for this? And if changing rods is the only way to get to 3.8, what are people using?
I had the same trouble, locating an drop in 3.8 kit for standard 993 bottom end.
You can buy a MAHLE 3.8 P/C kit which does slip in to your existing OEM engine bottom end here: https://msroadrace.com/Porsche-993-M...arch=993%203.8
Now it is the same kit for 993 and 964s apparently. Mahle has constructed a new design on the wristpin area, yet they claim to have still the same durability as before.
I have bought one of these sets and will mount it to my ongoing engine upgrade, and report back once all is mounted and tested.
