993 Forum 1995-1998
Anyone else having this problem w/ Morimoto projectors?
Old 01-24-2019, 02:43 AM
Churchill
Churchill's Avatar
Default Anyone else having this problem w/ Morimoto projectors?
Great product, but now my high beams are too high. Or more precisely, there is now such a divergence between the angle of the highs vs the lows that when the lows are adjusted properly, the highs are way too high, and when the highs are adjusted properly the lows are way too low. It's not even close. My lights are undamaged and the projectors are installed properly.
The only adjustability that can be potentially created is in the bracket that mounts the projector to the light housing. The projector angle needs to be changed in order to bring the low beam into greater parallelity with the high beam light. I was thinking of using washers between the turnbuckle and bracket to angle the projector.
Curious if anyone else has had this problem. I can't be the only one.
(pics stolen from this 6speed thread: https://www.6speedonline.com/forums/...what-took.html)
Old 01-24-2019, 10:34 AM
JB 911
JB 911's Avatar
While it may not be ideal setup didn't a few wire the the lows to stay on with the highs? Would that help?
Old 01-24-2019, 08:40 PM
Churchill
Churchill's Avatar
The Morimoto's already allow the low beams to stay on with the highs. The problem is the highs are shining up in the trees when the lows are adjusted properly.
For people with the projectors installed -- when you park in the garage, say, 5-10 feet from the wall, and put the high beams on, where is the fuzzy circle of high beam light concentrated? It should basically be right in the middle of the cutoff line of the low beams. For me it's a few inches above it, so out on the road it's way too high.
Old 01-24-2019, 10:12 PM
Chuck W.
Chuck W.'s Avatar
I can't help with your issue, sorry. But, if you call Retrofit's customer service number they may be able to help you out.
Below is a short video of mine when I was having an issue with a bad projector. It may help you compare your's to mine.
Good luck and keep us posted.
https://photos.google.com/share/AF1Q...5BMUQ5MnVQNFBR
Old 01-25-2019, 09:44 AM
k722070
k722070's Avatar
maybe you have one of those orange spacers in the wrong spot?
Old 01-26-2019, 12:17 PM
71-3.0-911's Avatar
This. Make sure you have all 3 and one isn't crushed too much, specifically the bottom one.
Old 01-26-2019, 02:27 PM
Chuck W.
Chuck W.'s Avatar
On both of my lights there were only 2 orange cushions per light. One of the side mounts was higher and would not accommodate one.
Old 01-26-2019, 05:03 PM
Churchill
Churchill's Avatar
Correctamundo.
The best way to describe high beam/low beam adjustment is that the oval of the high beam projection should basically rest in the cradle made by the low beam projection (the light cutoff line). On my car, at 10' away from the garage wall, the oval is several inches above the low beam cradle, which is why out on the road the highs are pointing up toward the trees. I've got it sorted out now -- used small washers to add a spacer to two of the turnbuckles on each bracket, aiming the low beam higher to be more in line with the highs, so I could then lower the whole assembly. I wish the 993 lights were like the old H1's and had independently adjustable highs and lows.
Old 01-26-2019, 09:11 PM
AX993
AX993's Avatar
Old 01-26-2019, 10:56 PM
rbeggs
rbeggs's Avatar
Default Same here.
I installed a set of the Morimoto projectors about a year ago and have the same problem. I recall checking the orange washer situation and being satisfied that the installation was "correct". The next step, never taken, was to call Retrofit for some advice but I've never gotten around to it, Mainly because my cynicism got the best of me. It seemed unlikely they'd have an answer. I do however take pleasure in knowing that I'm not alone. This may inspire me to get off my duff and attack the problem again.
Thanks for posting that.
-rb
Old 01-26-2019, 11:27 PM
AX993
AX993's Avatar
Old 01-26-2019, 11:59 PM
Churchill
Churchill's Avatar
I will post some pics of the procedure tomorrow...
Old 01-27-2019, 05:52 PM
AX993
AX993's Avatar
Old 01-27-2019, 08:06 PM
Churchill
Churchill's Avatar
Originally Posted by glenn '88 944S
Got impatient and took apart my lights and tried to use heat to "un-compress' the orange washers but it didn't work. So I went ahead and put nylon washers on the upper two turnbuckles to aim them towards the stock high beams. Will try to take another road test in the next few days, weather permitting.
I don't have pics in front of me, but the concept is simple enough. If the highs are too high, you want to adjust the low beams higher so you can then adjust the complete assembly lower.
The projector is mounted on a metal bracket with turnbuckles, that in turn attach to a fiberglass bracket that attaches to the plastic light housing with three security T20 torx bolts.
There's not much play in the fiberglass bracket, but there is under the turnbuckles. That's where the washers go. Between the turnbuckle and underside of the fiberglass bracket.
Old 01-27-2019, 08:59 PM
AX993
AX993's Avatar
Quick Reply: Anyone else having this problem w/ Morimoto projectors?
