Dual Distributor Rebuild Durability
Related question on distributor reliability. How many of you have had hall sensor failure?
I haven't finished diagnosis, but I'm pretty sure my 2nd hall sensor has now failed. This essentially means the distributor has to be tossed as that component isn't available separately from the overall distributor.
And these things aren't cheap, even used.
https://edelweiss.smugmug.com/Cars/P...or/i-2RrWzx6/A
https://edelweiss.smugmug.com/Cars/P...or/i-MqHmNX8/A
https://edelweiss.smugmug.com/Cars/P...or/i-3bzncrt/A
Then I went to Google images and tracked down a couple of vendors that had what appeared to have the identical sensor on a different plate. All it was a matter of was drilling the rivets and reinstalling.
Sorry, I am not at my usual PC, so I cannot at this time be of further help.
You can try Newark or DigiKey, but you might be there forever going through the list of sensors.
I went from the part numbers on the sensor itself, which came up with nothing. Other than the Bosch icon.
